Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Which SSD upgrade should I go for
So, i am about to buy the SSD upgrade for my mac and i have two choices...
OWC Drive with Read of 501mbs and Write of 503mbs at £186. This drive is made by a company.
https://www.thebookyard.com/product.php?...
or
Fledgling P12 with Read of 473mbs and Write of 465mbs at £141.15. This drive is not made by a company per say but is the result of crowdfunding for more affordable drives for the macbook pro.
https://www.ebay.co.uk/itm/1TB-Solid-Sta...
So my question is this. Do i go with the cheaper one or will the 28mbs / 38mbs make enough of a difference on my mid 2012 retina that it would be worth paying the extra £45
Это хороший вопрос?
Оценка 0
2 Комментариев
I'd go for the P12. I know that 3rd party SATA based SSD adapters and SSDs are fine. It's the PCIe based one that is unreliable.
из
What is the warranty on the cheap one? I just wrote the company to try to get more information on them.
из
Добавить комментарий
Ответов (2)
Выбранное решение
It shouldn't make a difference, my bigger concern is the quality of the product between the two and not so much the write speed. I sincerely doubt you will notice any major difference between the two so if you consider them both a quality product, go with the cheaper one.
Был ли этот ответ полезен?
Оценка 1
You’re not going to notice the difference. I know some people do not like OWC drives but I personally use then in my machines and have zero issues. Just be aware if you plan to use an adapter you may run into fitment issues. Good Luck!
Оценка 0
Добавьте свой ответ
Skyler Chie будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 85
