Ic power repair issues
When i replace the old ic power by a new one i get a honks when i connect the board to a power supply with 4.2v. What should can be this honks?
Это хороший вопрос?
Оценка 0
1 Комментарий:
When you say “replaced power IC”, do you mean you separated the board, desoldered the main PMIC, and put a new one on? If not, what are you referring to? The battery? Also, what is meant by honks?
из
Добавить комментарий
