Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Вопросов 20 Показать все
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
из
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
из
Добавьте свой ответ
Nathan Mayo будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 64
