Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Всё, что нужно знать о ремонте и разборке iPhone SE второго поколения, который был выпущен в апреле 2020 года.
Вопросов 20 Показать все
Phone keeps restarting itself after house/screen replacement
I replaced the housing and screen for an iPhone SE 2020, but the phone keeps shutting off and rebooting itself. I’ve tried disconnecting the front camera, charging port, wireless charger, and antenna, and it keeps doing that. Does anyone have any suggestions about what I can do?
I have a new charging flex cable coming in to be replaced, so that might be the issue for me, even though I have it disconnected from the main motherboard. The battery itself measures at 3.7V.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
Hey there, this is a common issue on iPhone X and above models when the housing is replaced or the back glass is changed or the earpiece is changed or the power button strip. Would you be able to provide me with the Panic Log so I can check it and probably pinpoint the issue? You will find Panic Logs in Settings -> Privacy -> Analytics & Improvements -> Analytics Data -> and Search for panic-full-xxxx-xxxx.ips and attach screenshots of the latest available panic log. Cheers!
Был ли этот ответ полезен?
Оценка 0
6 Комментариев:
Is there a specific part of the log you want to see? It's extremely long, but here are a couple of pictures from the top of the log:
https://ibb.co/3pCVDTL
https://ibb.co/NSG71Hc
https://ibb.co/4VGXYmy
I also have the .ips for it if you want to see that.
из
As per the log its a charging port issue, Try a known good OEM pulled charging port and let me know!
из
@iammyron07 I suspected that that was causing the issue, but wasn't 100% sure. I have one on the way from repairpartsUSA, so hopefully that fixes all my issues. Thank you for confirming!
из
You're welcome, Always happy to help! :D
из
I have same problem with se2020 today,
Can i ask u how i can find it out myself for what part the panic log is for, how do you see its for the charging port .
Can a nfc antenna cause same problem?
из
Показать 1 больше комментариев
Добавьте свой ответ
Eric Strohm будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 438
