Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
Razer Blade 15 Advanced Screen Replacement
I have the Razer Blade 15 Advance with an RTX 2060. Last night my son threw a car at it an broke the screen. I see some replacement screens on amazon but they say that they are for the GTX 1060/1070 models. Will this screen work for my RTX 2060 model?
https://www.amazon.com/EM-EMAJOR-TECH-LL...
Это хороший вопрос?
Оценка 1
2 Комментариев
Can you take out the screen and post a picture of the back here? To do this, go to Options>Edit on your question. Put your cursor after the last piece of text and hit enter/return on your keyboard. Select the image icon, then select Upload. After your image is finished uploading, select it. Finally, select "Submit Revision"
из
Sure I'll take it apart this weekend and send some pics.
из
Добавить комментарий
Ответов (1)
Выбранное решение
I’m almost certain it will work with your current model(same screen size, same amount of pins on the connector). If you want to be sure you got the right one, I found a screen with the same model number here.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I ordered this screen like 1 hour ago after I took it apart. I really appreciate the help and confirmation on my order.
из
Добавьте свой ответ
Anthony Johnson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 748
