Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
Why won’t my laptop turn on?
I had this laptop for over a year now, and it randomly just doesn’t turn on. I didn’t use it for 3 days and left it charging and when I want to use it. It didn’t turn on, I unplugged it and plugged it back. Nothing, I tried the battery reset. Still nothing. There is no lights, no motherboard turning on and no fans on. Please help. (Btw this is a AN515-54)
Это хороший вопрос?
Оценка 0
1 Комментарий:
Can you unplug the battery and press the power button while the laptop is connected to its charger?
из
Добавить комментарий
Ответов (2)
If the laptop suddenly doesn't turn on, and there are no lights, then it may not be charged.
Try making sure that all the parts of the AC adapter are securely connected together. Remove the battery and put it back in (if the laptop will allow). Then plug one end of the adapter into the laptop firmly, and plug the other end into a different electrical outlet than before.
If this doesn't work, then replace the adapter first. Then replace the battery.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I took it to my local Best Buy and they said it is a motherboard issue. I’m probably going to buy a new one. Because the repair cost is very very expensive
из
need to plug the charger into your acer nitro 5 until you hear click sound TWICE, most people were tricked by the first click sound and thought that was enough to plug the charger while in truth it need to plug till the second click sound appear.
Оценка 0
Добавьте свой ответ
DJSommerTime будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 8
За последние 30 дней: 10
За всё время: 2,204
