Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Why is my power button flashing
It’s on rest mode and it won’t turn on, I can’t restart it because it just keeps blinking no matter how long I hold it down for, I tried removing the battery and then plugging it back it but it didn’t work. Before when it was working it asked to download something and I pressed ok and then it froze on my Lock Screen and I held down the power button to restart it but then now it won’t turn on and the power button is just flashing, please help if you know how to fix this
Это хороший вопрос?
Оценка 3
Добавить комментарий
Ответов (6)
Наиболее полезный ответ
What did you download? Do you recall?
Here is a, rather wordy, video showing the interior.
https://www.youtube.com/watch?v=gjCriBHq...
Disconnect the main battery and then the RTC/CMOS battery in the middle of the screen with the black and red wires. Press power button for at least 30 seconds to discharge any power. This should reset the BIOS. Reconnect RTC/CMOS battery and main battery and reassemble.
Power on. Let us know how it goes.
If that fixes it then go to the Lenovo web site and run the diagnostics and update BIOS, if needed, and any other drivers:
https://pcsupport.lenovo.com/nz/en/produ...
https://pcsupport.lenovo.com/au/en/produ...
Otherwise try pushing the Novo button hole (2nd one back on left side of case)
How to Open the Novo Button Menu - Two Ways:
1st Method
  • Turn off the computer.
  • Press Fn and the power to open the Novo Button menu.
2nd Method
  • Step 1. Turn off the computer.
  • Step 2. Open the LCD screen and press the Novo button.
The Novo Button Menu can be displayed before the operating system starts. From the menu, you can choose to
  • • Open the BIOS/UEFI setup utility
  • • Open the boot device selection menu
  • • Open the Windows startup options screen
Note: From the Windows startup options screen, you can then choose to
  • Start your computer using a recovery drive
  • Reset your computer
  • Open advanced options screen
Был ли этот ответ полезен?
Оценка 3
7 Комментариев:
Yes I’ve tried this before but it didn’t work and I did it again right now but it still just keeps flashing, but when the battery is full the light stops flashing and it just stays on, I’ve tried to press caps lock to see if it would turn on and it didn’t, thank you tho. Is there any other advice I can try?
из
Oh and no I don’t remember what I downloaded I think it was something to do with protection but I don’t really remember
из
@masterahma
* You could possibly have download some malware. Never download anything unless you know what it is. Especially note its source and alleged name.
* I have added information in the "Answer" section above on how to use the NOVO button. See if you can get into the BIOS/UEFI setup utility Let us know how it goes.
*Charging light (left side 2nd from back) Indicate whether the computer is connected to ac power:
•Solid white: connected to ac power; battery capacity 91%–100%
•Solid amber: connected to ac power; battery capacity 1%–90%
•Off: not connected to ac power
из
I have tried and it’s still the same, the light is still blinking I’m sorry it took a while to respond I’ve just been busy but thank you for trying, do you any other advice?
из
Hi @masterahma,
When you had the system open did you try disconnecting the main battery and with just the power supply plugged in seeing if it boots up or at least gets to the BIOS screen - of course observing lights and what they do.
If you were more clinical with your responses it would be very helpful as you are my eyes and ears and I wouldn't have to ask as many questions. Things like, for example, if the lights blink in a particular pattern and colour. What the Power light is doing and what the Charging light is doing. Troubleshooting requires keen observation and a slow gentle pace so you notice things.
из
Показать 2 больше комментариев
I had the same problem with my power button steadily flashing and used suggestions from other sites to change my sleep / hibernate options but that didn't work. I then took advise to update the BIOS and "Boom! Problem Solved".
Оценка 2
I found this fix: https://www.youtube.com/watch?v=XFGCtigP...
Download the Intel Graphics Control Panel Ap from the microsoft store, if you don't already have it.
Disable the feature under power settings called "refresh rate switching". It is an energy savings strategy that causes the blinking issue. It took me YEARS to find this fix!!! Thank you AIC Video on Youtube!!!
Оценка 1
Most likely you have your monitor/display options set to an external/secondary display. Once the Lenovo logo appears and then fades back to black, with the power button still flashing, press:
Fn(hold) + F10(tap)
This function switches between display options. If this fixes the problem and you are not able to interact with the login screen with the touchpad, simply press
Fn(hold) + F6(tap)
This function disables and re-enables the touchpad
Really hope this helps anyone still in need of a fix for this very annoying issue!
Cheers!
Оценка 1
the unplugged the battery and cmos battery the 30secs press power button works for me
Оценка 0
Well I think you download something what did you download do you have any idea? Because it I think it effect your system.
And for more you can check out this: My laptop is not powering on its just that light blinking
Оценка 0
Добавьте свой ответ
Rahma будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 39
За последние 30 дней: 189
За всё время: 51,864
