Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
A laptop by Toshiba with a 15.8" display and runs Windows. Has a straightforward repair similar to most laptops. Requires only a screwdriver.
How to safely remove plugs
Hi,
I would like to know how to safely unplug some connections underneath my keyboard. My first attempt ended in frustration as the plug would not come out of the socket. I did not want to force it , as I was afraid I would break the connection. Every video I see online shows the plug coming out with ease, but not mine. Am I doing something wrong?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Off hand, I would try pushing down gently on the two white tabs in the indent on your photo and pulling gently.
I believe the tabs on the wire-side hook-in under the top of the socket.
Any how try doing that gently
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
David Peddle будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 95
