Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Вопросов 20 Показать все
Panic (cpu 0 calller) after battery repair
Did a battery repair on iPad 5 Cellular. After customer left with ipad it began to boot loop every 3 minutes. Shows PANIC (CPU 0 CALLER). I have already replaced the charging port but still the same issue.
Any ideas?
Thanks
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
This is likely some issue with a sensor checking in. This is almost always the case after a battery repair. It’s possible the new battery is defective. Or the battery connector on the board sustained some damage during the repair. The data pins in particular are prone to bend.
Can you post a copy of the full panic report? Or at least screenshots of the first page or so?
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I have a picture of the panic log below
из
@store0667 The panic you posted indicates pretty much what I expected. There is a battery sensor (TG0B) which the iPad is not getting communication from. The issue is going to most likely be the new battery, or damage to one of the pins on the battery connector. I would recommend taking the board out to inspect the underside of the battery connector.
из
Here is some of the Panic log.
Thanks
Оценка 0
1 Комментарий:
How did you disconnect the battery before disconnecting the screens? Or what did you use? Does as mentioned before sound like damaged pins on the board. A pain but remove the board completely and take a look for damage.
из
Добавьте свой ответ
BP 667 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 7
За последние 30 дней: 17
За всё время: 925
