Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Вопросов 20 Показать все
Can you remove the little circle around the home button?
picture So im repairing my iPad 5 rn and i saw this little plastic ring around my homebutton, i decided to remove it as its just a piece of rubber and plastic, but maybe it served a purpose? lol. Does anyone know if this is bad or can i continue?
Update (08/30/2022)
This, teh left (rubber was first atteched to the back of the plastic one and surrounded the homebutton together.)
Это хороший вопрос?
Оценка 1
3 Комментариев
Can you add a picture of the object?
из
@Traxced
We can’t see the images as they are a comment
You need to add them to the original question
You need to edit the question then add them. :-)
из
@hellomacos yep i noticed lol, i did it now!
из
Добавить комментарий
Ответов (2)
Выбранное решение
If you mean the gasket? Then you will likely need this. It helps to mount the button to the display and stabilize it. It also provides some very minimal protection against liquid entry.
Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4. Изображение
Продукт
iPad 5/6/Air 2/mini 4 Home Button Gasket
$6.99
Был ли этот ответ полезен?
Оценка 5
Hi
From what the photos show that is a gasket
This isn’t necessarily needed but it helps keep dirt out
You could use some light adhesive on it or order a new one
But as I said your iPad should work without it but it’s recommended that it’s there
Hopefully this helps
Any questions please ask
Оценка 2
Добавьте свой ответ
Traxced будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 208
