Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
Вопросов 20 Показать все
Antenna board fpc connector
Hi I was repairing a phone for a friend and while I was trying to put the antenna on after replacing charging port it snapped off. Obviously it has there Data on etc so they don't want to replace phone. Is this repairable at all.
please see the red box where it's broken
Это хороший вопрос?
Оценка 0
5 Комментариев
@flannelist I took it to a repair shop to be done. Just wondering if it will likely damage phone or data on phone or will this be unlikely to happen.
из
@ai33 Of course it depends on the repair shop, but in general, no, that repair should not damage anything else in the phone and there's no reason for you to lose data. If either of those things happen the repair shop has an obligation to make things right.
из
Ok so I don't need to worry about it then and everything should be safe and I should not lose data or any other damage to phone.
из
@ai33 For a private repair company, that should be true. If you took it to Apple, all they would do would be to substitute a refurbished phone for yours and yes, you would lose all your data.
из
Yep I took it to a local independent shop with good reviews
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
You'll need some soldering experience, but it's certainly doable. Hardest bit will be the pin in the center depending on the tools you have.
These connectors are pretty standard as well, so if you don't have the one that pulled off, it should be easy to source another one.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Am gonna take it to a phone shop to repair but one of them said about heat in that area as sensitive chips could damage the sensitive chips. Also still have the one that pulled off it's still on the other end
из
из
Добавьте свой ответ
Ai33 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 87
