How to put belt on the mower deck
how dose the belt go on the mower deck
Это хороший вопрос?
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Это хороший вопрос?
Mike,
Usually there are two belts. One goes around two pulleys, a front pulley under the motor and one on the mower deck. Additionally, there is usually a spring tensioner pulley that rides against the belt to allow it to work and for ease of routing.
The second belt goes under the first belt and is routed on a common pulley with the drive belt and both (or all three) of the mower blade pulleys.
Here is a crazy looking exploded view of a craftsman mower deck
And here is a better diagram of it all put together. I think you can get an idea of belt routing out of this one:
Был ли этот ответ полезен?
Do I have to bend the metal bracket that keeps belt from slipping off pulley to put a new belt on. The belt will not go on pulley unless I do bend it back.
The bracket that holds the blade belt on the pulley is stable and will not move. How do I get the belt on pulley without bending it
За последние 24 час(ов): 10
За последние 7 дней: 53
За последние 30 дней: 157
За всё время: 64,828
7 Комментариев
how to put blade belt on modile 917289031.
из cynthia
What about 3 belt craftsman.I have 2 ride mowers one is 2 belt other is 3belt ?? The deck belt patterns are different
из Vincesnowgren
is this for a deck on a 7000 series 42" cut mower?
из gary
This is. For the 2ooo series. Model 247.288852. Serial # 1A192B10186
из Vincesnowgren
46 inch deck
из Vincesnowgren
Показать 2 больше комментариев
