Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Repair and disassembly information for HP 15s Laptop PCs, specifically 15-dw models. The HP 15-dw is a lightweight and portable, mid-range laptop series designed for everyday use, featuring 15.6-inch displays, 11th generation Intel processors, DDR4 memory, and SSD storage. Identified by model numbers starting with 15-dw or 15s-dy.
Battery replacement 15-dw3021nia S/N CND04651YZ
I found 2 models HT03XL which is the original replacement of my battery, and also an exact similar model TF03XL. the later seemed to be with higher voltage 11.55v, higher capacity, and 33% cheaper above that... looks like a battery with more advanced cells, and I want it instead of my same old battery, but I am not sure if it is compatible. on HP site there was a couple BIOS updates to support new battery models, but they didn't list what are these new models. is this battery TF03XL compatible with my laptop?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
From what I can tell it is not compatible, unfortunately.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Packet Loss Gamer будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 132
