Asus MeMO Pad 8 ME181C Speaker Assembly Replacement
Выберете то, что вам нужно
Инструменты
Insert a plastic opening tool into the seam between the rear case and the screen.
Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
Use the pointed end of a spudger to disconnect the speaker cable.
Gently pull the speaker cable out of its channel along the left side of the device.
