Black and Decker PS1800 Switch Replacement
Введение
Перейти к шагу 1This guide describes how to replace the Black and Decker PS1800 switch. A soldering gun is necessary to replace the switch. Personal protective equipment is suggested.
Выберете то, что вам нужно
Инструменты
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Identify the switch in center of the drill.
Remove the screws from the switch.
Remove the switch cover.
Еще один человек закончил это руководство.
