Core Assembly Removal
Выберете то, что вам нужно
    1. Core Assembly Removal, Power down your watch: шаг 1, изображение 1 из 2 Core Assembly Removal, Power down your watch: шаг 1, изображение 2 из 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Спросите у FixBot
      Добавить комментарий
    2. Core Assembly Removal, Unfasten the back cover: шаг 2, изображение 1 из 1
      • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
      Спросите у FixBot
    3. Core Assembly Removal, Loosen the back cover adhesive: шаг 3, изображение 1 из 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Спросите у FixBot
    4. Core Assembly Removal, Pry up the back cover assembly: шаг 4, изображение 1 из 3 Core Assembly Removal, Pry up the back cover assembly: шаг 4, изображение 2 из 3 Core Assembly Removal, Pry up the back cover assembly: шаг 4, изображение 3 из 3
      • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
      • Pry upwards to loosen the back cover assembly. This may require some force.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
      • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
      Спросите у FixBot
    5. Core Assembly Removal, Disconnect the sensor assembly cable: шаг 5, изображение 1 из 2 Core Assembly Removal, Disconnect the sensor assembly cable: шаг 5, изображение 2 из 2
      • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    6. Core Assembly Removal, Remove the back cover assembly: шаг 6, изображение 1 из 3 Core Assembly Removal, Remove the back cover assembly: шаг 6, изображение 2 из 3 Core Assembly Removal, Remove the back cover assembly: шаг 6, изображение 3 из 3
      • Remove the back cover assembly.
      Спросите у FixBot
    1. Core Assembly Removal, Disconnect the microphone cable: шаг 7, изображение 1 из 2 Core Assembly Removal, Disconnect the microphone cable: шаг 7, изображение 2 из 2
      • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
      Спросите у FixBot
    2. Core Assembly Removal, Unfasten the core assembly: шаг 8, изображение 1 из 1
      • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
      Спросите у FixBot
    3. Core Assembly Removal, Pry up the core assembly: шаг 9, изображение 1 из 2 Core Assembly Removal, Pry up the core assembly: шаг 9, изображение 2 из 2
      • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
      • Pry upwards to loosen the core assembly.
      • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
      Спросите у FixBot
    4. Core Assembly Removal, Swing open the core assembly: шаг 10, изображение 1 из 3 Core Assembly Removal, Swing open the core assembly: шаг 10, изображение 2 из 3 Core Assembly Removal, Swing open the core assembly: шаг 10, изображение 3 из 3
      • Carefully swing open the core assembly like the front cover of a book.
      • Avoid straining or tearing the display cables at the bottom of the core assembly.
      Спросите у FixBot
    5. Core Assembly Removal, Disconnect the display cables: шаг 11, изображение 1 из 3 Core Assembly Removal, Disconnect the display cables: шаг 11, изображение 2 из 3 Core Assembly Removal, Disconnect the display cables: шаг 11, изображение 3 из 3
      • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
      Спросите у FixBot
    6. Core Assembly Removal, Remove the core assembly: шаг 12, изображение 1 из 2 Core Assembly Removal, Remove the core assembly: шаг 12, изображение 2 из 2
      • Remove the core assembly.
      Спросите у FixBot
Заключение
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
Еще один человек закончил это руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
262 626 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 48 885 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 33
За всё время: 1,543
