DJI Phantom 2 Vision Gimbal Housing Replacement
Введение
Перейти к шагу 1This guide demonstrates how to replace the gimbal housing of your DJI Phantom 2 Vision. When completing the disassembly make sure to clean any residue that may be surrounding the screws before beginning, as doing this will ensure no over or under-tightening of screws may occur. Also, make sure to verify the size of the screws if you plan on replacing them, they are 6mm.
Note: The drone we worked on already had the propellers removed. However, you will need to remove the propellers before Step 4. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
Flip the drone over so the bottom is facing up.
Use a Phillips #00 screwdriver to remove the four 6 mm screws.
To access the screws, slowly pull back on the mount in the opposite direction.
Slowly lift the gimbal housing from the device.
Gently disconnect the camera cable from the cable connected to the motherboard.
Push on alternating sides of the connector and pull straight away from the socket.
