DJI Phantom 2 Vision Outer Shell Replacement
Введение
Перейти к шагу 1This guide demonstrates how to remove the outer shell of the DJI Phantom 2 Vision.
Before beginning disassembly, clean any residue around the screws to prevent over- or under-tightening.
You may need to remove the outer shell of the DJI Phantom 2 Vision if your drone has sustained damage to the structure or if you need to access the internal components for repair.
Before you begin, ensure your device is powered off and disconnected from the charger.
Note: The drone used in this guide already had its propellers removed. However, you must remove the propellers before taking off the top shell. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
Flip Device so Motors face down
Unscrew 4 (6mm) screws next to the landing gear on each arm using a #2 Allen head bit.
The final screws are located around the base of the four unscrewed sections on each arm from step 1.
Unscrew each of the 12 screws. There are two (9mm) Allen head screws on each arm. Remove them using #2 Allen head bit. The final screw is located at end of each arm. Remove it using 00 Philips head bit.
Slowly lift the Shell off the device.
Disconnect the GPS wire from the motherboard, it should pull out easily with minimal force.
To reassemble your device, follow the instructions in reverse order.
