Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Dell Inspiron 15 5502 Case Removal
Kind-hearted, spirited Man
Kind-hearted, spirited Man и еще один участник
Последнее обновление September 25, 2021
10 мин.
Легко
Руководство, предоставленное сообществом
Граммар-наци
This guide will teach you to remove the back case.
This should be done before most repairs of the 5502.
Выберете то, что вам нужно
Инструменты
Показать больше…
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell Inspiron 15 5502 Case Removal, Screws: шаг 2, изображение 1 из 1
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell Inspiron 15 5502 Case Removal, Getting the base cover out: шаг 3, изображение 1 из 1
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell Inspiron 15 5502 Case Removal, Battery disconecting: шаг 5, изображение 1 из 2 Dell Inspiron 15 5502 Case Removal, Battery disconecting: шаг 5, изображение 2 из 2
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell Inspiron 15 5502 Case Removal, Drain the power: шаг 6, изображение 1 из 1
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
Заключение
If you were following another article and was said to follow this guide, now you can go and follow it/continue in the step you stopped!
Участник с: 08/15/21
1 052 Репутация
Автор 4 руководств
Команду
Android Alliance Участник Android Alliance
Community
92 членов
Автор 735 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 22
За всё время: 1,481
