Dell Inspiron 15-5565 Wireless Card Replacement
Введение
Перейти к шагу 1In this guide, you will successfully learn how to replace the wireless card on a Dell Inspiron 15-5565. Please see this page to perform troubleshooting.
Выберете то, что вам нужно
Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
Eject the optical drive by pressing the eject button.
Push out the optical drive bracket using the iFixit opening tool.
Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
Slide the bracket to remove it.
Disconnect the two cables from the wireless card.
