Google Pixel 2 XL Charging Assembly Replacement
Выберете то, что вам нужно
  1. Google Pixel 2 XL Charging Assembly Replacement, SIM Card: шаг 1, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement, SIM Card: шаг 1, изображение 2 из 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
    • Press firmly to eject the tray.
    Спросите у FixBot
    Добавить комментарий
  2. Google Pixel 2 XL Charging Assembly Replacement: шаг 2, изображение 1 из 1
    • Remove the SIM card tray from the phone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Спросите у FixBot
  3. Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: шаг 3, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: шаг 3, изображение 2 из 2
    • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    Спросите у FixBot
  4. Google Pixel 2 XL Charging Assembly Replacement: шаг 4, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 4, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 4, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    Спросите у FixBot
  5. Google Pixel 2 XL Charging Assembly Replacement: шаг 5, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 5, изображение 2 из 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
    • Do not cut along the left edge; there are delicate display cables that can be damaged.
    • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
    Спросите у FixBot
  6. Google Pixel 2 XL Charging Assembly Replacement: шаг 6, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 6, изображение 2 из 2
    • Slide the opening pick down the right side of the phone to separate the display adhesive.
    Спросите у FixBot
  7. Google Pixel 2 XL Charging Assembly Replacement: шаг 7, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 7, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 7, изображение 3 из 3
    • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
    • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
    Спросите у FixBot
  8. Google Pixel 2 XL Charging Assembly Replacement: шаг 8, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 8, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 8, изображение 3 из 3
    • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
    Спросите у FixBot
  9. Google Pixel 2 XL Charging Assembly Replacement: шаг 9, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 9, изображение 2 из 2
    • Gently lift the display from the right side of the phone, opening it like a book.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
    • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
    • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
    Спросите у FixBot
  10. Google Pixel 2 XL Charging Assembly Replacement: шаг 10, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 10, изображение 2 из 2
    • Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
    • The clip securing this cover is along the bottom edge.
    • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
    • Remove the connector cover.
    • Make sure to keep this component so you can reinstall it during reassembly.
    Спросите у FixBot
  11. Google Pixel 2 XL Charging Assembly Replacement: шаг 11, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 11, изображение 2 из 2
    • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    Спросите у FixBot
  12. Google Pixel 2 XL Charging Assembly Replacement: шаг 12, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use tweezers to remove any tape from the display connector cover.
    Спросите у FixBot
  13. Google Pixel 2 XL Charging Assembly Replacement: шаг 13, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 13, изображение 2 из 2
    • Insert the point of a spudger into the small hole on the edge of the display connector cover.
    • Use the spudger to pry the cover out of its recess.
    Спросите у FixBot
  14. Google Pixel 2 XL Charging Assembly Replacement: шаг 14, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 14, изображение 2 из 2
    Спросите у FixBot
  15. Google Pixel 2 XL Charging Assembly Replacement, Midframe: шаг 15, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove eleven 3.8 mm Phillips screws securing the midframe.
    Спросите у FixBot
  16. Google Pixel 2 XL Charging Assembly Replacement: шаг 16, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 16, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 16, изображение 3 из 3
    • Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
    • Remove the midframe.
    Спросите у FixBot
  17. Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: шаг 17, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the battery connector.
    Спросите у FixBot
  18. Google Pixel 2 XL Charging Assembly Replacement, Motherboard: шаг 18, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement, Motherboard: шаг 18, изображение 2 из 2
    • Use the point of a spudger to disconnect the front-facing camera connector.
    • During reassembly, it's easiest to attach the front camera to the motherboard, then insert the motherboard.
    Спросите у FixBot
  19. Google Pixel 2 XL Charging Assembly Replacement: шаг 19, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 19, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 19, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the right Active Edge sensor connector.
    • Disconnect the antenna cable.
    Спросите у FixBot
  20. Google Pixel 2 XL Charging Assembly Replacement: шаг 20, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 20, изображение 2 из 2
    • Use the point of a spudger to disconnect the fingerprint sensor connector.
    Спросите у FixBot
  21. Google Pixel 2 XL Charging Assembly Replacement: шаг 21, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 21, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the left Active Edge sensor connector.
    Спросите у FixBot
  22. Google Pixel 2 XL Charging Assembly Replacement: шаг 22, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 22, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the charging assembly connector.
    Спросите у FixBot
  23. Google Pixel 2 XL Charging Assembly Replacement: шаг 23, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 23, изображение 2 из 2
    • Use the point of a spudger to disconnect the front-facing sensor assembly connector.
    Спросите у FixBot
  24. Google Pixel 2 XL Charging Assembly Replacement: шаг 24, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 24, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 24, изображение 3 из 3
    • Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
    • The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance.
    • Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
    • Remove the motherboard.
    • Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
    • When reinstalling the motherboard, move all the cables and connectors out of the way of the board and make sure all connectors are aligned with their respective sockets.
    Спросите у FixBot
  25. Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: шаг 25, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: шаг 25, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: шаг 25, изображение 3 из 3
    • Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
    • If you're having trouble, try inserting the flat end of a spudger into the gap at the base of the phone and slowly pry up.
    Спросите у FixBot
  26. Google Pixel 2 XL Charging Assembly Replacement: шаг 26, изображение 1 из 1
    • Remove the loudspeaker from the phone.
    Спросите у FixBot
  27. Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: шаг 27, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: шаг 27, изображение 2 из 2
    • Use the point of a spudger to disconnect the white antenna cable to the right of the battery.
    Спросите у FixBot
  28. Google Pixel 2 XL Charging Assembly Replacement: шаг 28, изображение 1 из 1
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the bottom of the back of the phone for about a minute, in order to soften the adhesive securing the charging assembly.
    Спросите у FixBot
  29. Google Pixel 2 XL Charging Assembly Replacement: шаг 29, изображение 1 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 29, изображение 2 из 3 Google Pixel 2 XL Charging Assembly Replacement: шаг 29, изображение 3 из 3
    • Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case.
    Спросите у FixBot
  30. Google Pixel 2 XL Charging Assembly Replacement: шаг 30, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 30, изображение 2 из 2
    • Gently pull the USB-C port out of its recess in the phone case.
    • The antenna board is still adhered to the phone case. Do not remove the charging assembly or strain the flex cable connecting the antenna board and the USB-C port.
    Спросите у FixBot
  31. Google Pixel 2 XL Charging Assembly Replacement: шаг 31, изображение 1 из 2 Google Pixel 2 XL Charging Assembly Replacement: шаг 31, изображение 2 из 2
    • Slowly slide the point of a spudger underneath the antenna board to separate the adhesive tape under the board.
    • Pry slowly and carefully to avoid putting too much strain on the board.
    Спросите у FixBot
  32. Google Pixel 2 XL Charging Assembly Replacement: шаг 32, изображение 1 из 1
    • Lift the charging assembly out of the phone case.
    Спросите у FixBot
Заключение
33 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
223 844 Репутация
Автор 416 руководств
12 Комментарии к руководству
Take your time removing the screen. I was bit impatient and cracked it :( . The screen is the most expensive part of the phone now so will be very costly for me to replace
Shan - Ответить Поделиться
Why do I need the Tesa 61395 Tape for this repair? I don’t see it used anywhere in the guide.
Jay Huxley - Ответить Поделиться
Hey Jay,
The Tesa tape is needed only necessary if you do not use the custom-cut back display panel adhesive.
Arthur Shi - Ответить Поделиться
Should I apply some kind of glue around the port?
Is there any possibility to keep it waterproof?
Erik Cej - Ответить Поделиться
Hi Erik,
Once you have opened the phone, there is no reliable DIY way to make it water resistant.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 76
За всё время: 26,000
