Google Pixel 4 Back Panel Replacement
Выберете то, что вам нужно
  1. Google Pixel 4 Back Panel Replacement, Remove the SIM card tray: шаг 1, изображение 1 из 3 Google Pixel 4 Back Panel Replacement, Remove the SIM card tray: шаг 1, изображение 2 из 3 Google Pixel 4 Back Panel Replacement, Remove the SIM card tray: шаг 1, изображение 3 из 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    Спросите у FixBot
    Добавить комментарий
  2. Google Pixel 4 Back Panel Replacement, Heat the back panel glass: шаг 2, изображение 1 из 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
  3. Google Pixel 4 Back Panel Replacement, Apply a suction cup: шаг 3, изображение 1 из 2 Google Pixel 4 Back Panel Replacement, Apply a suction cup: шаг 3, изображение 2 из 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    Спросите у FixBot
  4. Google Pixel 4 Back Panel Replacement, Insert an opening pick: шаг 4, изображение 1 из 2 Google Pixel 4 Back Panel Replacement, Insert an opening pick: шаг 4, изображение 2 из 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Спросите у FixBot
  5. Google Pixel 4 Back Panel Replacement, Begin to slice the adhesive: шаг 5, изображение 1 из 3 Google Pixel 4 Back Panel Replacement, Begin to slice the adhesive: шаг 5, изображение 2 из 3 Google Pixel 4 Back Panel Replacement, Begin to slice the adhesive: шаг 5, изображение 3 из 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  6. Google Pixel 4 Back Panel Replacement, Slice the lefthand-side adhesive: шаг 6, изображение 1 из 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
    Спросите у FixBot
  7. Google Pixel 4 Back Panel Replacement: шаг 7, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 7, изображение 2 из 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
    Спросите у FixBot
  8. Google Pixel 4 Back Panel Replacement: шаг 8, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 8, изображение 2 из 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
    Спросите у FixBot
  9. Google Pixel 4 Back Panel Replacement, Slice righthand-side adhesive: шаг 9, изображение 1 из 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
    Спросите у FixBot
  10. Google Pixel 4 Back Panel Replacement: шаг 10, изображение 1 из 3 Google Pixel 4 Back Panel Replacement: шаг 10, изображение 2 из 3 Google Pixel 4 Back Panel Replacement: шаг 10, изображение 3 из 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
    Спросите у FixBot
  11. Google Pixel 4 Back Panel Replacement, Slice the top-side adhesive: шаг 11, изображение 1 из 2 Google Pixel 4 Back Panel Replacement, Slice the top-side adhesive: шаг 11, изображение 2 из 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
    Спросите у FixBot
  12. Google Pixel 4 Back Panel Replacement, Lift up the back panel: шаг 12, изображение 1 из 3 Google Pixel 4 Back Panel Replacement, Lift up the back panel: шаг 12, изображение 2 из 3 Google Pixel 4 Back Panel Replacement, Lift up the back panel: шаг 12, изображение 3 из 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
    Спросите у FixBot
  13. Google Pixel 4 Back Panel Replacement: шаг 13, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 13, изображение 2 из 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
    Спросите у FixBot
  14. Google Pixel 4 Back Panel Replacement, Disconnect the battery: шаг 14, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
    Спросите у FixBot
  15. Google Pixel 4 Back Panel Replacement: шаг 15, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 15, изображение 2 из 2
    • Use a pair of tweezers to remove the battery connector shield.
    Спросите у FixBot
  16. Google Pixel 4 Back Panel Replacement: шаг 16, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 16, изображение 2 из 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  17. Google Pixel 4 Back Panel Replacement: шаг 17, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 17, изображение 2 из 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
    Спросите у FixBot
  18. Google Pixel 4 Back Panel Replacement, Disconnect the back panel connector: шаг 18, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
    Спросите у FixBot
  19. Google Pixel 4 Back Panel Replacement: шаг 19, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 19, изображение 2 из 2
    • Use a pair of tweezers to remove the back panel connector cover.
    Спросите у FixBot
  20. Google Pixel 4 Back Panel Replacement: шаг 20, изображение 1 из 2 Google Pixel 4 Back Panel Replacement: шаг 20, изображение 2 из 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
    Спросите у FixBot
  21. Google Pixel 4 Back Panel Replacement, Remove the back panel: шаг 21, изображение 1 из 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 292 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 230 руководств
1 Комментарий к руководству
Ist ja wohl ein Witz. Schritt 12-17 braucht man nicht, Akku kann drin bleiben. Die wichtigen Teil, wie Transfer von Blitzeinheit und Ladeantennen fehlt.
King Sui - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 20
За последние 30 дней: 102
За всё время: 6,070
