Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
HP 15-da0002dx Fan Replacement
Abigail Aron
Abigail Aron и еще один участник
Последнее обновление December 20, 2019
Нет оценки
Средне
Ненаглядные фото
Недостающие детали
If your HP Notebook 15-da0002dx laptop is overheating, the system randomly shuts down, or the fan is making noise, use this guide to replace the fan. The fan’s purpose it to cool the laptop by drawing cooler air from the outside and expelling warm air from the inside.
Make sure your computer is not randomly shutting down because of other issues. If the fan stopped working, usually a “CPU fan failure” or “power supply failure” pop-up message appears on the screen.
Before using this guide, power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
Выберете то, что вам нужно
Инструменты
Показать больше…
  1. HP 15-da0002dx Fan Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Fan Replacement: шаг 2, изображение 1 из 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Fan Replacement: шаг 3, изображение 1 из 2 HP 15-da0002dx Fan Replacement: шаг 3, изображение 2 из 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Fan Replacement: шаг 4, изображение 1 из 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Fan Replacement: шаг 5, изображение 1 из 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Fan Replacement: шаг 6, изображение 1 из 2 HP 15-da0002dx Fan Replacement: шаг 6, изображение 2 из 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Fan Replacement: шаг 7, изображение 1 из 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Fan Replacement, Battery: шаг 8, изображение 1 из 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Fan Replacement: шаг 9, изображение 1 из 2 HP 15-da0002dx Fan Replacement: шаг 9, изображение 2 из 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx Fan Replacement, Fan: шаг 10, изображение 1 из 2 HP 15-da0002dx Fan Replacement, Fan: шаг 10, изображение 2 из 2
    • Hold the fan in place and remove the one 8.0 mm screw from the fan .
  11. HP 15-da0002dx Fan Replacement: шаг 11, изображение 1 из 1
    • Pull out the connector for the fan cable using the opening tool or spudger.
  12. HP 15-da0002dx Fan Replacement: шаг 12, изображение 1 из 1
    • Carefully take out the fan from the computer.
Заключение
Еще один человек закончил это руководство.
Abigail Aron
Участник с: 09/04/19
1 097 Репутация
Автор 5 руководств
Команду
University of Alabama, Team S2-G8, Bedsole Fall 2019 Участник University of Alabama, Team S2-G8, Bedsole Fall 2019
UA-BEDSOLE-F19S2G8
4 членов
Автор 6 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 1,515
