JBL Clip 2 Motherboard Replacement
Введение
Перейти к шагу 1The motherboard of the the JBL Clip 2 is the central unit that allows the unit to have all of it's different functions. The device will be taken apart and the motherboard will be removed and replaced.
Выберете то, что вам нужно
Инструменты
Показать больше…
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
There will be six 3 mm T8 screws under the cap, remove these six screws.
If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
The motherboard is now exposed, and to extract it you must now desoder the eight connection points to the battery, audio AUX cord, and the Mic.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
2 человек успешно провели ремонт по этому руководству.
