Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
Rie Kuraoka
Rie Kuraoka и 3 другие участники
Последнее обновление March 25, 2020
5 - 15 минут
Средне
If the auxiliary or USB port is not working in your Lenovo Flex 6-11IGM (model #: 81A70005US), use this guide to help you replace them.
These two ports are connected to each other so removing them are easy to do together. They allow the user to plug either an aux cord or USB into the laptop and the user is able to either output sound or transfer data. If the aux cord or USB is not going into the respective ports, or they aren’t accepting the inputs of them, you may need to replace the ports themselves if the aux cord or the USB aren’t damaged themselves.
Before beginning, make sure you power off the device and make sure the laptop is closed for an easier and safer replacement.
Выберете то, что вам нужно
Инструменты
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 2, изображение 1 из 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 2, изображение 2 из 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 4, изображение 1 из 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 4, изображение 2 из 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: шаг 5, изображение 1 из 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: шаг 5, изображение 2 из 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: шаг 5, изображение 3 из 3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 6, изображение 1 из 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: шаг 6, изображение 2 из 2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
Заключение
Еще один человек закончил это руководство.
Rie Kuraoka
Участник с: 01/23/20
913 Репутация
Автор 7 руководств
Команду
Cal Poly, Team S7-G10, Paton Spring 2020 Участник Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 членов
Автор 9 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 411
