Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Logitech MX Ergo Scroll Wheel (fixing slippage)
Eiti
Eiti и 4 другие участники
Последнее обновление May 7, 2024
10 мин.
Легко
Руководство, предоставленное сообществом
Буллеты!
If scrolling the scroll wheel starts becoming imprecise or seemingly "slow", it may be because there's filth accumulation affecting the movement sensor. Because of the rolling movement of the wheel, dust accumulates in the form of a ball and will block the photo-sensor intermittently. There's some discussion on the internet that may lead us to think that this behavior is an app configuration problem (if you're using Logitech Options), but after opening the device I confirmed that, in my case, it was just dirty. Please note that you just have to disassemble the device using the instructions you will find right here on iFixit up until step #2 of the Disassembly Guide to reach the scroll wheel, so you may skip steps #3-#11 of the guide below.
Выберете то, что вам нужно
Инструменты
Показать больше…
  1. Logitech MX Ergo Scroll Wheel (fixing slippage), Logitech MX Ergo: шаг 1, изображение 1 из 1
    • Remove six T6 screws from the bottom
  2. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 2, изображение 1 из 1
    • Slide a prying tool under the rightmost button and follow the seam back till the top half unclips
  3. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 3, изображение 1 из 1
    • Carefully lift the top shell.
    • Do not remove the flap from the connector.
    • Release the flex ribbon from its socket.
  4. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 4, изображение 1 из 1
    • Lever the scrollwheel sub-assembly free
  5. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 5, изображение 1 из 1
    • Unplug the battery from the mainboard, carefully lifting the plug marked red.
    • Unscrew the three screws holding the battery submodule.
  6. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 6, изображение 1 из 2 Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 6, изображение 2 из 2
    • Unscrew the bottom left screw holding down the fwd/rev buttons, lifting the assembly to the side
    • Unplug the flex ribbon indicated in blue, coming from the power board below. Remove the six screws holding the main motherboard (one indicated orange here, just out of shot).
  7. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 7, изображение 1 из 1
    • Unscrew the three screws holding the power board i place. Take care not to loose the power switch below as you take the last bits apart.
    • These three screws are a bit shorter than the rest, so keep them separate
  8. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 8, изображение 1 из 2 Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 8, изображение 2 из 2
    • There you go, all disassembled. Now remove spilled coffee.
  9. Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: шаг 9, изображение 1 из 3 Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: шаг 9, изображение 2 из 3 Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: шаг 9, изображение 3 из 3
    • The right click lever comes out after the bracket covering the ribbon cable
    • The Right click lever comes out through the front/top of the mouse
    • Then the circuit boards can be removed
  10. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 10, изображение 1 из 3 Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 10, изображение 2 из 3 Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 10, изображение 3 из 3
    • Under the circuit boards there is three piece that need to come out next
    • The first has one screw and two clear pieces that transmit the light from the circuit board to the outside of the mouse and hole to allow another to pass through it
    • Then the computer selector switch lever can come out the front/top of the mouse
    • After that the connecting light indicator transmitter will fall out and the left click lever can be removed
  11. Logitech MX Ergo Scroll Wheel (fixing slippage), Remove dust/filth: шаг 11, изображение 1 из 1
    • With the cover open, look at the scroll wheel on the side that has a hollow central area and roll the wheel. You should look for any dirt/filth that may have accumulated on this inner side of the wheel in the form of a little ball that interferes with the sensors (see image on next step).
  12. Logitech MX Ergo Scroll Wheel (fixing slippage): шаг 12, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Carefully remove it using tweezers, so you don't bump the assembly out of alignment.
Заключение
2 человек успешно провели ремонт по этому руководству.
Eiti
Участник с: 10/10/16
177 Репутация
1 руководство автора
5 Комментариев
Before going to all that work, I tried using a can of air to forcefully blow into the gap on each side of the scroll wheel. I don't know if it got any lint out, but it started working perfectly again without having to disassemble it.
Robert Fraser - Ответить
This is much more complex than it needs to be. Do step 1, then step 2, and then instead of step 3 you put the top half of the mouse to the right side of the mouse with the top on the table, like opening a clamshell to the right. The ribbon to the top half is plenty long, and you have full access to the scroll wheel for cleaning and you can skip to steps 11 and 12.
Vacuum and forced air didn't work for me, as my 6+ year old mouse had a bunch of hair and lint trapped in the mechanism, but with tweezers I was able to extract enough that the mouse works great again.
Further note that step 1 will not work with a normal T6 bit driver, as two of the screws are recessed pretty far, screw holes are too narrow for a 4mm bit to fit. Luckily, I had a dedicated T6 driver with a narrow shaft that fit in.
alan - Ответить
I completely agree with you @alan9532 . Someone added a bunch of unnecessary steps after I created the guide.
We just need to remove the screws, lift the cover and clean the wheel, that's it.
I tried removing the unnecessary steps. I hope they don't add them back again!
Thank you for pointing it out.
Eiti -
Hi, what parts need replacing if cleaning the wheel and housing has no effect? My mouse can scroll back, but not forwards anymore.
Cindy du Plessis - Ответить
Hi @cindyatay
By your message, it isn't clear if the wheel stopped "mechanically" rolling in one direction or if it doesn't respond (on the screen cursor) to the movement on the wheel.
If it is a mechanical problem, I would check if the torsion spring (the metal part near the wheel) is correctly nested.
Good luck!
Eiti -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 9
За последние 7 дней: 63
За последние 30 дней: 213
За всё время: 2,261
