OnePlus 9 Pro Screen Replacement
Выберете то, что вам нужно
  1. OnePlus 9 Pro Screen Replacement, Rear Glass: шаг 1, изображение 1 из 1
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
    Спросите у FixBot
    Добавить комментарий
  2. OnePlus 9 Pro Screen Replacement: шаг 2, изображение 1 из 1
    Спросите у FixBot
  3. OnePlus 9 Pro Screen Replacement: шаг 3, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 3, изображение 2 из 2
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
    Спросите у FixBot
  4. OnePlus 9 Pro Screen Replacement: шаг 4, изображение 1 из 1
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
    Спросите у FixBot
  5. OnePlus 9 Pro Screen Replacement: шаг 5, изображение 1 из 1
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
    Спросите у FixBot
  6. OnePlus 9 Pro Screen Replacement: шаг 6, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 6, изображение 2 из 2
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Спросите у FixBot
  7. OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: шаг 7, изображение 1 из 2 OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: шаг 7, изображение 2 из 2
    • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
    Спросите у FixBot
  8. OnePlus 9 Pro Screen Replacement: шаг 8, изображение 1 из 3 OnePlus 9 Pro Screen Replacement: шаг 8, изображение 2 из 3 OnePlus 9 Pro Screen Replacement: шаг 8, изображение 3 из 3
    • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
    • Use an opening pick to remove the flash module by the camera.
    • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
    • Use an opening pick to pry off the motherboard cover.
    Спросите у FixBot
  9. OnePlus 9 Pro Screen Replacement: шаг 9, изображение 1 из 1
    • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
    • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
    • The other three screws are black and are also 4.8 mm-long.
    Спросите у FixBot
  10. OnePlus 9 Pro Screen Replacement: шаг 10, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 10, изображение 2 из 2
    • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
    Спросите у FixBot
  11. OnePlus 9 Pro Screen Replacement: шаг 11, изображение 1 из 1
    • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
    Спросите у FixBot
  12. OnePlus 9 Pro Screen Replacement: шаг 12, изображение 1 из 1
    • Use the spudger to pry up and remove the loudspeaker.
    Спросите у FixBot
  13. OnePlus 9 Pro Screen Replacement, Battery: шаг 13, изображение 1 из 3 OnePlus 9 Pro Screen Replacement, Battery: шаг 13, изображение 2 из 3 OnePlus 9 Pro Screen Replacement, Battery: шаг 13, изображение 3 из 3
    • Use an opening pick or tweezers to carefully peel back the adhesive on the bottom of the wireless charging module.
    Спросите у FixBot
  14. OnePlus 9 Pro Screen Replacement: шаг 14, изображение 1 из 3 OnePlus 9 Pro Screen Replacement: шаг 14, изображение 2 из 3 OnePlus 9 Pro Screen Replacement: шаг 14, изображение 3 из 3
    • Pry on the bottom of the flash module off using a pick and use tweezers to get under the module without ripping it.
    • Be careful unplugging the module as the cable is very delicate.
    Спросите у FixBot
  15. OnePlus 9 Pro Screen Replacement: шаг 15, изображение 1 из 1
    • Use a Phillips #000 screwdriver to remove the eleven 4.8 mm-long screws securing the motherboard cover.
    Спросите у FixBot
  16. OnePlus 9 Pro Screen Replacement: шаг 16, изображение 1 из 3 OnePlus 9 Pro Screen Replacement: шаг 16, изображение 2 из 3 OnePlus 9 Pro Screen Replacement: шаг 16, изображение 3 из 3
    • Pry around the phone with picks to remove the motherboard cover.
    Спросите у FixBot
  17. OnePlus 9 Pro Screen Replacement: шаг 17, изображение 1 из 1
    • Lift off the motherboard cover.
    Спросите у FixBot
  18. OnePlus 9 Pro Screen Replacement: шаг 18, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 18, изображение 2 из 2
    • Pry up and disconnect the press connector ribbon cable in the top right with a spudger.
    • Make sure not to damage them in the process.
    Спросите у FixBot
  19. OnePlus 9 Pro Screen Replacement: шаг 19, изображение 1 из 3 OnePlus 9 Pro Screen Replacement: шаг 19, изображение 2 из 3 OnePlus 9 Pro Screen Replacement: шаг 19, изображение 3 из 3
    • Use a spudger to disconnect the two interconnect cables from the motherboard by prying the connector straight up from its socket.
    Спросите у FixBot
  20. OnePlus 9 Pro Screen Replacement: шаг 20, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 20, изображение 2 из 2
    • Take care not to bend or puncture battery during the removal procedure—a bent battery may leak dangerous chemicals or cause a fire.
    • Remove the battery from the phone by slowly pulling up on the red tabs.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen side for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Спросите у FixBot
  21. OnePlus 9 Pro Screen Replacement, Screen: шаг 21, изображение 1 из 2 OnePlus 9 Pro Screen Replacement, Screen: шаг 21, изображение 2 из 2
    • Use the spudger to unplug the ribbon cable that connects the screen to the rest of the phone.
    Спросите у FixBot
  22. OnePlus 9 Pro Screen Replacement: шаг 22, изображение 1 из 1
    • Place the suction cup on the glass towards the bottom of the screen.
    Спросите у FixBot
  23. OnePlus 9 Pro Screen Replacement: шаг 23, изображение 1 из 1
    • Heat the adhesive holding the screen onto the phone by using the heat gun on the edges of the screen.
    • Be sure to use caution when using the heat gun.
    Спросите у FixBot
  24. OnePlus 9 Pro Screen Replacement: шаг 24, изображение 1 из 3 OnePlus 9 Pro Screen Replacement: шаг 24, изображение 2 из 3 OnePlus 9 Pro Screen Replacement: шаг 24, изображение 3 из 3
    • Put the jimmy into the bottom edge of the screen.
    • Use an opening pick to slice the adhesive, and place opening picks around the perimeter as you slice to avoid the adhesive from resealing.
    • Reheat the screen as needed.
    Спросите у FixBot
  25. OnePlus 9 Pro Screen Replacement: шаг 25, изображение 1 из 2 OnePlus 9 Pro Screen Replacement: шаг 25, изображение 2 из 2
    • Carefully pull up on the suction cup to pull the screen away from the phone.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Averie
Участник с: 02/17/25
294 Репутация
Автор 2 руководств
Команда
University of Memphis, Team 1-1, Sneed Spring 2025 Участник University of Memphis, Team 1-1, Sneed Spring 2025
UM-SNEED-S25S1G1
4 членов
Автор 15 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 61
За последние 30 дней: 256
За всё время: 2,842
