Введение
Use this guide to remove the back cover assembly on your TicWatch Pro 3 GPS.
You’ll need replacement adhesive to reattach the back cover assembly when reassembling the device. Your device will function normally, but will lose its IP (Ingress Protection) rating.
Выберете то, что вам нужно
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
Pry upwards to loosen the back cover assembly. This may require some force.
Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
3 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
