Redmi Note 8 Pro battery replacement
Выберете то, что вам нужно
    1. Redmi Note 8 Pro battery replacement, Heat the rear glass: шаг 1, изображение 1 из 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Спросите у FixBot
      Добавить комментарий
    2. Redmi Note 8 Pro battery replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Insert an opening pick: шаг 2, изображение 3 из 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Спросите у FixBot
    3. Redmi Note 8 Pro battery replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Slice the adhesive: шаг 3, изображение 2 из 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Спросите у FixBot
    4. Redmi Note 8 Pro battery replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Slice the adhesive: шаг 4, изображение 3 из 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    5. Redmi Note 8 Pro battery replacement: шаг 5, изображение 1 из 2 Redmi Note 8 Pro battery replacement: шаг 5, изображение 2 из 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Спросите у FixBot
    6. Redmi Note 8 Pro battery replacement: шаг 6, изображение 1 из 2 Redmi Note 8 Pro battery replacement: шаг 6, изображение 2 из 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
      Спросите у FixBot
    7. Redmi Note 8 Pro battery replacement, Remove the rear glass: шаг 7, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Remove the rear glass: шаг 7, изображение 2 из 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Спросите у FixBot
    1. Redmi Note 8 Pro battery replacement, Unfasten the motherboard cover screws: шаг 8, изображение 1 из 1
      • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
      Спросите у FixBot
    2. Redmi Note 8 Pro battery replacement, Pry up the motherboard cover: шаг 9, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Pry up the motherboard cover: шаг 9, изображение 2 из 2
      • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
      • Flip the opening pick sideways to pry up the motherboard cover.
      Спросите у FixBot
    3. Redmi Note 8 Pro battery replacement, Remove the motherboard cover: шаг 10, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Remove the motherboard cover: шаг 10, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Use a pair of tweezers or your fingers to remove the motherboard cover.
      Спросите у FixBot
    4. Redmi Note 8 Pro battery replacement, Disconnect the battery cable: шаг 11, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Disconnect the battery cable: шаг 11, изображение 2 из 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Спросите у FixBot
    1. Redmi Note 8 Pro battery replacement, Disconnect the power and volume button cable: шаг 12, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Disconnect the power and volume button cable: шаг 12, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Disconnect the power and volume button cable: шаг 12, изображение 3 из 3
      • Use a spudger to disconnect the power and volume button cable by prying the connector straight up from its socket.
      • Use your spudger to carefully fold the power and volume button cable to the side to free the battery.
      • Do not fold the cable sharply and only bend it to avoid cable damage.
      Спросите у FixBot
    2. Redmi Note 8 Pro battery replacement, Disconnect the display cable: шаг 13, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Disconnect the display cable: шаг 13, изображение 2 из 2
      • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
      Спросите у FixBot
    3. Redmi Note 8 Pro battery replacement, Disconnect the interconnect cable: шаг 14, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Disconnect the interconnect cable: шаг 14, изображение 2 из 2
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      Спросите у FixBot
    4. Redmi Note 8 Pro battery replacement, Free the battery: шаг 15, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Free the battery: шаг 15, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Free the battery: шаг 15, изображение 3 из 3
      • During the following step do not fold the cables sharply and only bend them to avoid cable damage.
      • Fold the display and the interconnect flex cable towards the charging port in order to get free access to both battery pull tabs and the battery.
      • You might want to use a small piece of tape to temporarily stick the cables onto your working surface to avoid accidentally damaging them during the battery removal.
      Спросите у FixBot
    5. Redmi Note 8 Pro battery replacement, Remove the stretch-release adhesive: шаг 16, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Remove the stretch-release adhesive: шаг 16, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Remove the stretch-release adhesive: шаг 16, изображение 3 из 3
      • The battery is secured to the rear case with two pieces of stretch-release adhesive.
      • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      • Use a pair of blunt nose tweezers or a clean fingernail to peel down both battery adhesive pull-tabs to un-stick them from the top edge of the battery.
      Спросите у FixBot
    6. Redmi Note 8 Pro battery replacement, Remove the pull-tabs: шаг 17, изображение 1 из 3 Redmi Note 8 Pro battery replacement, Remove the pull-tabs: шаг 17, изображение 2 из 3 Redmi Note 8 Pro battery replacement, Remove the pull-tabs: шаг 17, изображение 3 из 3
      • Grab the first pull-tab with a pair of blunt nose tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
      • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
      • Don't press down on the battery. Hold the phone firmly by its sides.
      • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
      • Pull at a low angle so the strip doesn't snag on the edge of the battery.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
      Спросите у FixBot
    7. Redmi Note 8 Pro battery replacement: шаг 18, изображение 1 из 3 Redmi Note 8 Pro battery replacement: шаг 18, изображение 2 из 3 Redmi Note 8 Pro battery replacement: шаг 18, изображение 3 из 3
      • Repeat the previous pull-tab removal procedure on the second pull-tab.
      • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
      • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      Спросите у FixBot
    8. Redmi Note 8 Pro battery replacement, Remove the battery: шаг 19, изображение 1 из 2 Redmi Note 8 Pro battery replacement, Remove the battery: шаг 19, изображение 2 из 2
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
24 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
262 420 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 41 937 руководств
9 Комментарии к руководству
hello, i think the guide could be very helpful, how ever, i don't know where to find the battery. can somebody help me please.
it would be very helpful, thank you in advance.
Roy Morris - Ответить Поделиться
Hello Roy, sorry for the late reply, but in case you are still looking: The Xiaomi Redmi Note 9 Pro Battery is available in the iFixit Store!
Manuel Haeussermann - Ответить Поделиться
After I replace the battery, the phone just shows a blinking white led light.I put it charging all night but nothing happened. I managed to show the xiaomi logo and then the battery indicator showing the thunder icon blinking, and it seems it is not charging. I thought it was a faulty battery but I bought another replacement and I still have the same issue. I had to put my old battery to be able to keep using my phone. Does anybody what is the issue? thanks!
Dani Mourinho - Ответить Поделиться
it looks that i had very bad luck with the batteries i tried earlier. I bought this one and worked fantastic! No blinking problem.Highly recommended: https://www.aliexpress.com/item/10050054... (select the model BN53)
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 74
За последние 30 дней: 396
За всё время: 29,515
