Samsung Galaxy A10e Motherboard Cover Replacement
Введение
Перейти к шагу 1Prereq for replacing the motherboard cover in your Samsung Galaxy A10.
Выберете то, что вам нужно
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tip of a spudger or tweezers to remove the antenna cover.
7 человек успешно провели ремонт по этому руководству.
Один комментарий
I have looked literally everywhere and nobody is covering the top motherboard 2 connectors w/ Ribbons on top the black squares one camera and the 1 to the right how does that 1 to the right connect with the ribbon please help thank you
