Samsung Galaxy Note10+ 5G Screen Replacement
Выберете то, что вам нужно
    1. Samsung Galaxy Note10+ 5G Screen Replacement, Heat the rear cover: шаг 1, изображение 1 из 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Спросите у FixBot
    3. Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: шаг 3, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: шаг 3, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Begin to slice the adhesive: шаг 3, изображение 3 из 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    4. Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: шаг 4, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: шаг 4, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice around the perimeter of the phone: шаг 4, изображение 3 из 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      Спросите у FixBot
    5. Samsung Galaxy Note10+ 5G Screen Replacement, Lift off the rear cover: шаг 5, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Lift off the rear cover: шаг 5, изображение 2 из 2
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      Спросите у FixBot
    1. Samsung Galaxy Note10+ 5G Screen Replacement, Lift up the metal cover: шаг 6, изображение 1 из 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      Спросите у FixBot
    2. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 7, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      Спросите у FixBot
    3. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the battery: шаг 8, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the battery: шаг 8, изображение 2 из 2
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      Спросите у FixBot
    4. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the wireless charging coil: шаг 9, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the wireless charging coil: шаг 9, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      Спросите у FixBot
    5. Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: шаг 10, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: шаг 10, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the wireless charging coil: шаг 10, изображение 3 из 3
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      Спросите у FixBot
    1. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the display cable: шаг 11, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the display cable: шаг 11, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    2. Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the touch layer: шаг 12, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Disconnect the touch layer: шаг 12, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the S-Pen touch layer cable connector from the motherboard.
      Спросите у FixBot
    3. Samsung Galaxy Note10+ 5G Screen Replacement, Loosen the adhesive: шаг 13, изображение 1 из 1
      • Prepare an iOpener and apply it to the left edge of the display for one minute.
      Спросите у FixBot
    4. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: шаг 14, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: шаг 14, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement, Slice the left side adhesive: шаг 14, изображение 3 из 3
      • Apply a suction cup to the heated edge of the display, as close to the edge as possible.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
      • Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
      Спросите у FixBot
    5. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 15, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 15, изображение 2 из 2
      • Slide the opening pick along the left side towards the bottom left corner to slice the adhesive.
      • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
      Спросите у FixBot
    6. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 16, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 16, изображение 2 из 2
      • Insert a second opening pick and slide it along the left side towards the top left corner to slice the adhesive.
      • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    7. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the bottom side adhesive: шаг 17, изображение 1 из 1
      • Prepare an iOpener and apply it to the bottom edge of the phone for one minute.
      Спросите у FixBot
    8. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 18, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 18, изображение 2 из 2
      • Insert a third opening pick into the gap on the bottom edge of the phone.
      • Slide the opening pick to the bottom right corner, slicing the adhesive.
      • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    9. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the top side adhesive: шаг 19, изображение 1 из 1
      • Prepare an iOpener and apply it to the top edge of the phone for one minute.
      Спросите у FixBot
    10. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 20, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 20, изображение 2 из 2
      • Insert a fourth opening pick into the gap on the top edge of the phone.
      • Slide the opening pick to the top right corner, slicing the adhesive.
      • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    11. Samsung Galaxy Note10+ 5G Screen Replacement, Slice the right side adhesive: шаг 21, изображение 1 из 1
      • Prepare an iOpener and apply it to the right edge of the phone for one minute.
      Спросите у FixBot
    12. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 22, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 22, изображение 2 из 2
      • Slide the opening pick from the top right corner down towards the bottom right corner of the phone to slice the adhesive.
      • The display will begin to separate from the phone as you get closer to the bottom edge.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
      Спросите у FixBot
    13. Samsung Galaxy Note10+ 5G Screen Replacement, Remove the screen: шаг 23, изображение 1 из 2 Samsung Galaxy Note10+ 5G Screen Replacement, Remove the screen: шаг 23, изображение 2 из 2
      • Don't try to completely remove the screen yet, as there are still some cables routed through the phone's frame.
      • Lift the screen up from the top edge of the phone.
      • Don't lift the screen higher than about a 15º angle above the device.
      Спросите у FixBot
    14. Samsung Galaxy Note10+ 5G Screen Replacement: шаг 24, изображение 1 из 3 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 24, изображение 2 из 3 Samsung Galaxy Note10+ 5G Screen Replacement: шаг 24, изображение 3 из 3
      • Thread the display and S-Pen touch layer cables through their cutouts on the phone frame.
      • Remove the display.
      • Remove any leftover adhesive before installing a new display.
      • Follow this guide for instructions on how to apply adhesive to the replacement screen.
      • Be sure to test your repairs before installing new adhesives.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
17 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 859 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 46 859 руководств
2 Комментарии к руководству
Thank you so much. Well put together, even as a tech head I would not have attempted this without a guide and this is the place to come for any guide required!!
Sly Si 84 - Ответить Поделиться
Dear Sir
My note 10 plus screen broken. I need a new screen.
Tariq Hasan - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 14
За последние 30 дней: 103
За всё время: 8,543
