Samsung Galaxy S21+ Back Cover Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S21+ Back Cover Replacement, Heat the bottom edge: шаг 1, изображение 1 из 1
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Спросите у FixBot
  3. Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Спросите у FixBot
  4. Samsung Galaxy S21+ Back Cover Replacement, Heat the right edge: шаг 4, изображение 1 из 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    Спросите у FixBot
  5. Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: шаг 5, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Спросите у FixBot
  6. Samsung Galaxy S21+ Back Cover Replacement, Heat the top edge: шаг 6, изображение 1 из 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
    Спросите у FixBot
  7. Samsung Galaxy S21+ Back Cover Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S21+ Back Cover Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S21+ Back Cover Replacement: шаг 7, изображение 3 из 3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Спросите у FixBot
  8. Samsung Galaxy S21+ Back Cover Replacement, Heat the left edge: шаг 8, изображение 1 из 1
    • Heat an iOpener and apply it to the left edge of the back cover for two minutes.
    Спросите у FixBot
  9. Samsung Galaxy S21+ Back Cover Replacement: шаг 9, изображение 1 из 3 Samsung Galaxy S21+ Back Cover Replacement: шаг 9, изображение 2 из 3 Samsung Galaxy S21+ Back Cover Replacement: шаг 9, изображение 3 из 3
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
    Спросите у FixBot
  10. Samsung Galaxy S21+ Back Cover Replacement, Remove the back cover: шаг 10, изображение 1 из 2 Samsung Galaxy S21+ Back Cover Replacement, Remove the back cover: шаг 10, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using double-sided tape, follow this guide.
    Спросите у FixBot
Заключение
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
5 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
261 085 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 236 руководств
2 Комментарии к руководству
I can't seem to find a good guide on how to affix the new glue for the back of a Galaxy S21+ (Plus). (USA - T-Mobile). The glue on the provided replacement looks different than the glue I removed, it goes around the cameras, whereas before there wasn't any glue there.
Sam C - Ответить Поделиться
In addition, even in your own video I found on YouTube, it shows a completely different adhesive layout being used. (https://www.youtube.com/watch?v=axCXYLE6... / "Samsung Galaxy S21 Plus Battery Replacement!"). Note, I have indeed have a Galaxy S21+ (SM-G996UZKATMB to be exact), but the back is plastic, not glass, like a like of guides for this phone allude to. I'm confused.
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 63
За последние 30 дней: 312
За всё время: 18,937
