Samsung Galaxy S23 Screen Replacement
Выберете то, что вам нужно
    1. Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Спросите у FixBot
      Добавить комментарий
    1. Samsung Galaxy S23 Screen Replacement, Heat the right edge: шаг 2, изображение 1 из 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Спросите у FixBot
    2. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Спросите у FixBot
    3. Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: шаг 4, изображение 3 из 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Спросите у FixBot
    4. Samsung Galaxy S23 Screen Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Спросите у FixBot
    5. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 6, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 6, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 6, изображение 3 из 3
      • Insert a second opening pick at the bottom right corner.
      • Rotate it around the bottom right corner to separate the adhesive.
      Спросите у FixBot
    6. Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: шаг 7, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: шаг 7, изображение 2 из 2
      • Slide your opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    7. Samsung Galaxy S23 Screen Replacement, Heat the left edge: шаг 8, изображение 1 из 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Спросите у FixBot
    8. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 9, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 9, изображение 2 из 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Спросите у FixBot
    9. Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: шаг 10, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: шаг 10, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: шаг 10, изображение 3 из 3
      • Insert a third opening pick at the bottom left corner.
      • Slide your pick toward the top left corner to separate the adhesive.
      • Leave the pick in the top left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    10. Samsung Galaxy S23 Screen Replacement, Heat the top edge: шаг 11, изображение 1 из 1
      • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
      Спросите у FixBot
    11. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 12, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 12, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: шаг 12, изображение 3 из 3
      • Insert a fourth opening pick at the top left corner.
      • Rotate it around the top left corner to separate the adhesive.
      Спросите у FixBot
    12. Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: шаг 13, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: шаг 13, изображение 2 из 2
      • Slide your opening pick to the top right corner to separate the adhesive.
      • Leave the pick in the top right corner to prevent the adhesive from resealing.
      Спросите у FixBot
    13. Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: шаг 14, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: шаг 14, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: шаг 14, изображение 3 из 3
      • There's a remaining patch of adhesive directly under the flash.
      • Line up the tip of an opening pick with the flash cutout.
      • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
      • You should see the opening pick through the flash cutout.
      • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
      • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
      Спросите у FixBot
    14. Samsung Galaxy S23 Screen Replacement, Remove the back cover: шаг 15, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Remove the back cover: шаг 15, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Remove the back cover: шаг 15, изображение 3 из 3
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Спросите у FixBot
    1. Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: шаг 16, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: шаг 16, изображение 2 из 2
      • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Спросите у FixBot
    2. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: шаг 17, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: шаг 17, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: шаг 17, изображение 3 из 3
      • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Six screws securing the wireless charging coil
      • Seven screws securing the loudspeaker
      Спросите у FixBot
    3. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: шаг 18, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: шаг 18, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: шаг 18, изображение 3 из 3
      • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
      • Pry up to unclip the loudspeaker from the frame.
      Спросите у FixBot
    4. Samsung Galaxy S23 Screen Replacement: шаг 19, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement: шаг 19, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement: шаг 19, изображение 3 из 3
      • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
      Спросите у FixBot
    1. Samsung Galaxy S23 Screen Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
      • Use the point of your spudger to pry up and disconnect the battery press connector.
      Спросите у FixBot
    1. Samsung Galaxy S23 Screen Replacement, Disconnect the display: шаг 21, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Disconnect the display: шаг 21, изображение 2 из 2
      • Use the flat end of your spudger to pry up and disconnect the display cable press connector from the back of the screen.
      Спросите у FixBot
    2. Samsung Galaxy S23 Screen Replacement, Put the back cover on: шаг 22, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Put the back cover on: шаг 22, изображение 2 из 2
      • Put the back cover on the frame to protect the battery and your phone's internals from damage.
      • Don't apply new adhesive at this step, as you'll need to remove the back cover again to finish reassembly. The old adhesive will be enough to keep the back cover in place while you replace the screen.
      • Flip your phone over so the screen is facing up.
      Спросите у FixBot
    3. Samsung Galaxy S23 Screen Replacement, Tool and safety information: шаг 23, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Tool and safety information: шаг 23, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Tool and safety information: шаг 23, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      iFlex Opening Tool
      $11.99
      • The gap between the front glass and frame is very small. You'll need a thin, rigid tool such as an iFlex to create an initial gap.
      • Take the following safety precautions while removing the front glass during the next steps:
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp.
      • The front glass may shatter and spread shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
      Спросите у FixBot
    4. Samsung Galaxy S23 Screen Replacement, Heat the screen: шаг 24, изображение 1 из 1
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's almost too hot to touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Спросите у FixBot
    5. Samsung Galaxy S23 Screen Replacement, Insert an iFlex: шаг 25, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: шаг 25, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: шаг 25, изображение 3 из 3
      • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
      • Insert the iFlex at a downward angle in the earpiece speaker gap between the top edge of the front glass and frame.
      • Lift the suction handle with strong, steady force and lower the iFlex so it slides under the front glass. A large portion of the front glass may separate—that's fine.
      • The front glass will peel away from the display panel, causing it to appear discolored. This is normal. You will remove the display panel in a later step.
      • The iFlex only needs to be inserted just enough to separate the front glass and create an initial gap. If inserted too far, it may damage the front-facing camera.
      Спросите у FixBot
    6. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 26, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 26, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: шаг 26, изображение 3 из 3
      • Rotate the iFlex around one of the top corners of the front glass to separate enough adhesive to insert an opening pick.
      Спросите у FixBot
    7. Samsung Galaxy S23 Screen Replacement, Remove the front glass: шаг 27, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement, Remove the front glass: шаг 27, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement, Remove the front glass: шаг 27, изображение 3 из 3
      • Slide the opening pick around the perimeter of the front glass to separate the adhesive securing it to the frame.
      Спросите у FixBot
    8. Samsung Galaxy S23 Screen Replacement: шаг 28, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement: шаг 28, изображение 2 из 2
      • Lift the front glass off the frame and remove it.
      Спросите у FixBot
    9. Samsung Galaxy S23 Screen Replacement, Remove the screen panel: шаг 29, изображение 1 из 2 Samsung Galaxy S23 Screen Replacement, Remove the screen panel: шаг 29, изображение 2 из 2
      • Insert an opening pick under the screen panel.
      • If you're having trouble separating the adhesive, use a hair dryer or heat gun to heat the screen panel until it's warm to the touch.
      Спросите у FixBot
    10. Samsung Galaxy S23 Screen Replacement: шаг 30, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement: шаг 30, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement: шаг 30, изображение 3 из 3
      • Slide the opening pick around the perimeter of the screen panel to separate the adhesive securing it to the frame.
      Спросите у FixBot
    11. Samsung Galaxy S23 Screen Replacement: шаг 31, изображение 1 из 3 Samsung Galaxy S23 Screen Replacement: шаг 31, изображение 2 из 3 Samsung Galaxy S23 Screen Replacement: шаг 31, изображение 3 из 3
      • Grip a corner of the screen panel and slowly peel it off the frame to separate the remaining adhesive.
      • Remove the screen panel.
      • You're now ready to replace your screen.
      Спросите у FixBot
Заключение
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S23 Answers Community for troubleshooting help.
7 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
246 642 Репутация
Автор 1 203 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 48 766 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 49
За последние 7 дней: 293
За последние 30 дней: 1,346
За всё время: 22,723
