Sony Vaio VGN-SZ120P screen Replacement
Введение
Перейти к шагу 1Please try our Troubleshooting Guide prior to replacing your Display Assembly. This guide covers the detachment and assembly of the display.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged and turned off before performing any maintenance on the system.
Выберете то, что вам нужно
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
Remove the Torx security screw near the center of the battery-side edge.
Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
Pull the keyboard toward the mouse pad and gently lift up.
Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
Remove the keyboard.
Turn the laptop upside down.
Remove the three screws from the front mouse panel located on the bottom of the laptop.
Lift the mouse assembly just enough to access the connecting ribbon cable.
Lift the ribbon cable lock to remove the cable.
Carefully remove the mouse panel assembly and set aside.
Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
Before proceeding, remove all black tape holding down wires and other cabling.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pop off the antenna using a pair of tweezers.
Remove the seven philips screws holding the speaker assembly in place.
Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
To remove the webcam cable, lift up the connector from the logic board gently.
Unscrew the four securing screws, two on each side of the LCD.
Carefully remove the LCD. The speaker, bluetooth, and webcam assembly will come up with the display assembly.
2 человек успешно провели ремонт по этому руководству.
