Sony WH-1000XM4 Right Ear Pad Replacement
Введение
Перейти к шагу 1Prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove or replace the right ear pad on the Sony WH-1000XM4 wireless headphones.
The procedure to remove the left ear pad is the same, but the standalone guide can be found here.
Выберете то, что вам нужно
Инструменты
Place your headphones onto a work surface, ear pads facing up.
Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
Pivot the spudger down to unclip the long edge of the ear pad.
Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
Align the cushion over the speaker and press them firmly together to snap it into place.
Press around the entire edge of the cushion, making sure all the clips have engaged.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Еще один человек закончил это руководство.
