Toshiba Satellite 1805-S177 Hard Drive Replacement
Введение
Перейти к шагу 1This guide tells you how to replace the current hard drive in the laptop with one of better storage or functionality.
Выберете то, что вам нужно
Инструменты
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
