Toshiba Satellite C55-A5302 Screen Replacement
Введение
Перейти к шагу 1This guide will show you how to disassemble the parts necessary to remove and replace the screen.
Выберете то, что вам нужно
Power down the laptop and remove all power cords. After this is done, turn the laptop over.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to remove the screw covers in the lower corners of the screen.
Use the Phillips #1 screwdriver to unscrew the two screws in the lower corners of the screen.
Remove the two screws in the top corners with a Phillips #1 screwdriver. The screen will pop forward after removing the two screws.
Using the same Phillips #1 screwdriver, remove the three screws on the side of screen frame.
On the back of screen, lift up the plastic film and screen connector. Pop out the connector, and gently remove the screen.
Еще один человек закончил это руководство.
