Введение
Use this guide to replace or upgrade the hard drive in your Toshiba Satellite L305-S5946. If your hard drive is faulty or you want more storage, you should replace the hard drive.
Инструменты
Запчасти
Детали не указаны.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Slide the right battery bay latch to the right and hold.
While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Slide the hard drive to the left using your fingers.
Insert a plastic opening tool under the right side of the hard drive.
Carefully lift and remove the hard drive.
4 участников успешно повторили данное руководство.
