Toshiba Satellite S50-B RAM Replacement
Введение
Перейти к шагу 1This guide demonstrates how to replace the RAM on Toshiba Satellite S50-B. You will need the Phillips #0 screwdriver and a plastic opening tool.
Выберете то, что вам нужно
Инструменты
Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
Unscrew all 6.5mm screws on the bottom of the laptop using a Phillips #0 Screwdriver
Using the plastic opening tools, open the back cover and remove it from the laptop.
Push down on the clips on either side of the RAM stick evenly.
Pull out the RAM stick. Make sure the notches on the RAM stick align with the notches in the RAM holder.
3 человек успешно провели ремонт по этому руководству.
