Введение
Unable to feed your music through your favorite headphones? It might be time to replace your audio jack. Use this guide to replace the audio jack in an iPad Air 2 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
As you follow the directions, take special care to avoid prying in the following areas:
Home Button
Front Facing Camera
Main Camera
Place a suction cup over the iPad's front-facing camera and press down to create a seal.
Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
Slide the pick along the edge of the display, towards the headphone jack.
If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
Slide the left-hand opening pick down the edge of the display until you reach the corner.
Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
Continue lifting the display assembly from the front-facing camera side.
Pull the display slightly away from the bottom edge to completely separate it from the rear case.
Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Remove the three 1.3mm Phillips screws from the display cable bracket.
Remove the bracket.
Disconnect the two remaining digitizer cables underneath the display data cable.
Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
Two 1.6 mm
Two 1.3 mm
Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
Remove the two 1.8 mm Phillips screws securing the bracket covering the audio jack.
Use an opening pick to lift the bracket up from the headphone jack.
Remove the bracket.
Use the flat end of a spudger to disconnect the Facetime camera connector from its socket on the logic board.
Use the flat end of a spudger to pry up the adhesive securing the Facetime camera ribbon cable to the headphone jack ribbon cable underneath.
Fold up the FaceTime camera ribbon cable so that it is out of the way.
Disconnect the headphone jack cable connector from its socket on the logic board.
Slide an opening pick under the headphone jack ribbon cable to free it from the adhesive securing it to the rear case.
Remove the single 2.8 mm Phillips screw securing the headphone jack to the rear case.
Pull the headphone jack straight back out of its recess.
Remove the headphone jack assembly.
6 участников успешно повторили данное руководство.
