iPad Air 3 Power Button Cable Replacement
Выберете то, что вам нужно
  1. iPad Air 3 Power Button Cable Replacement, Prepare an iOpener: шаг 1, изображение 1 из 1
    • Strong adhesive holds the screen in place. In order to separate it, you'll first need to heat and soften the adhesive using an iOpener, hair dryer, or heat gun.
    • You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
    • Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
    Спросите у FixBot
    Добавить комментарий
  2. iPad Air 3 Power Button Cable Replacement, Create an opening gap: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • If your iPad's screen is badly cracked, wear skin and eye protection. Cover the screen with a smooth layer of clear packing tape to contain glass shards and help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    • Place a suction cup next to the iPad's home button and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • If you want to use the Anti-Clamp, a tool we designed to make the opening procedure easier, follow this guide.
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Don't pull too hard, or you may shatter the glass. If necessary, apply more heat to further soften the adhesive.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
    Спросите у FixBot
  3. iPad Air 3 Power Button Cable Replacement, Slice through the bottom adhesive: шаг 3, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement, Slice through the bottom adhesive: шаг 3, изображение 2 из 2
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
    Спросите у FixBot
  4. iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: шаг 4, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: шаг 4, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: шаг 4, изображение 3 из 3
    • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
    • Insert a second opening pick at the bottom left corner of the iPad.
    • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
    • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
    Спросите у FixBot
  5. iPad Air 3 Power Button Cable Replacement: шаг 5, изображение 1 из 1
    • Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    Спросите у FixBot
  6. iPad Air 3 Power Button Cable Replacement: шаг 6, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 6, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 6, изображение 3 из 3
    • Insert a third opening pick at the top left corner of the iPad.
    • Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
    • The front-facing camera is located right in the center of the iPad's top edge and can be damaged if the pick is inserted too far. Only insert the tip of the opening pick when cutting near the camera.
    Спросите у FixBot
  7. iPad Air 3 Power Button Cable Replacement: шаг 7, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 7, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 7, изображение 3 из 3
    • Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • Insert a fourth opening pick at the top right corner of the iPad.
    • Slide the opening pick down to the bottom right corner to cut the adhesive.
    • Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
    Спросите у FixBot
  8. iPad Air 3 Power Button Cable Replacement: шаг 8, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement: шаг 8, изображение 2 из 2
    • Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
    • Gently twist the pick to separate the display assembly from the iPad.
    • Don't try to remove the display all the way yet! It is still connected to the iPad's motherboard.
    • If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
    Спросите у FixBot
  9. iPad Air 3 Power Button Cable Replacement: шаг 9, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 9, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 9, изображение 3 из 3
    • Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
    • Don't lift the display more than 70° or you may damage the attached ribbon cables.
    Спросите у FixBot
  10. iPad Air 3 Power Button Cable Replacement: шаг 10, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement: шаг 10, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Remove the 1.9 mm Phillips screw that secures the battery power connector.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Спросите у FixBot
  11. iPad Air 3 Power Button Cable Replacement, Battery connector information: шаг 11, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement, Battery connector information: шаг 11, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement, Battery connector information: шаг 11, изображение 3 из 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Спросите у FixBot
  12. iPad Air 3 Power Button Cable Replacement, Disconnect the battery: шаг 12, изображение 1 из 1
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages.
    • Leave the battery blocker in place as you work.
    Спросите у FixBot
  13. iPad Air 3 Power Button Cable Replacement: шаг 13, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 13, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 13, изображение 3 из 3
    • Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
    • Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
    • You may need to angle the driver slightly in order to avoid straining the ribbon cables.
    • Remove the display connector cover bracket.
    Спросите у FixBot
  14. iPad Air 3 Power Button Cable Replacement: шаг 14, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 14, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 14, изображение 3 из 3
    • Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  15. iPad Air 3 Power Button Cable Replacement: шаг 15, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 15, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 15, изображение 3 из 3
    • Underneath, you'll find two additional display cable connectors.
    • Use your spudger to gently pry them up and disconnect them.
    Спросите у FixBot
  16. iPad Air 3 Power Button Cable Replacement: шаг 16, изображение 1 из 1
    • Remove the display assembly.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing display, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
    Спросите у FixBot
  17. iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket screws: шаг 17, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 2.4 mm-long screws
    Спросите у FixBot
  18. iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: шаг 18, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: шаг 18, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: шаг 18, изображение 3 из 3
    • Use a spudger to push the upper component bracket towards the upper edge and off of the clips located near the rear camera.
    Спросите у FixBot
  19. iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket: шаг 19, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket: шаг 19, изображение 2 из 2
    • Remove the upper component bracket.
    • During reassembly, make sure that the upper component bracket slides under the clips near the rear camera.
    Спросите у FixBot
  20. iPad Air 3 Power Button Cable Replacement, Disconnect the power button assembly: шаг 20, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement, Disconnect the power button assembly: шаг 20, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the front camera cable by lifting straight up on the press connector.
    Спросите у FixBot
  21. iPad Air 3 Power Button Cable Replacement, Remove the power button bracket screws: шаг 21, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two 4.3 mm-long screws securing the power button bracket to the rear case.
    Спросите у FixBot
  22. iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: шаг 22, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: шаг 22, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: шаг 22, изображение 3 из 3
    • Use a pair of tweezers to peel the power button assembly away from the rear case.
    • The power button is loose and may fall out of the rear case.
    Спросите у FixBot
  23. iPad Air 3 Power Button Cable Replacement, Loosen the adhesive: шаг 23, изображение 1 из 2 iPad Air 3 Power Button Cable Replacement, Loosen the adhesive: шаг 23, изображение 2 из 2
    • Apply a heated iOpener to the power button assembly for thirty seconds.
    Спросите у FixBot
  24. iPad Air 3 Power Button Cable Replacement, Remove the power button cable: шаг 24, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement, Remove the power button cable: шаг 24, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement, Remove the power button cable: шаг 24, изображение 3 из 3
    • Grip the power button bracket with a pair of tweezers.
    • Use an opening pick or halberd spudger to peel the power button cable away from the bracket.
    Спросите у FixBot
  25. iPad Air 3 Power Button Cable Replacement: шаг 25, изображение 1 из 3 iPad Air 3 Power Button Cable Replacement: шаг 25, изображение 2 из 3 iPad Air 3 Power Button Cable Replacement: шаг 25, изображение 3 из 3
    • Use an opening pick or a halberd spudger to peel the power button cable away from the bracket.
    • Remove the power button cable.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
    • During reassembly, transfer the ambient light sensor gasket over to the new power button cable.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to attach the new cable to the power button bracket.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 3 Answers community for help.
Еще один человек закончил это руководство.
Robert Boyd
Участник с: 02/01/21
33 363 Репутация
Автор 94 руководств
1 Комментарий к руководству
Will replacing this power button cable assembly also resolve the problem of the iPad Air 3rd gen not responding to a smart cover? If not, what part would need to be replaced? Thanks!
Ben - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 27
За последние 30 дней: 89
За всё время: 4,308
