Введение
Prerequisite only guide for removing the front panel assembly from an iPad Mini 3.
Инструменты
Запчасти
Детали не указаны.
Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
Slide the flat end of a spudger under the battery side of the digitizer board to begin separating it from the rear case.
Почти готово!
Заключение
