iPhone 11 Pro Max Taptic Engine Replacement
Выберете то, что вам нужно
    1. iPhone 11 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Спросите у FixBot
      Добавить комментарий
    1. iPhone 11 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 11 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Спросите у FixBot
    2. iPhone 11 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Спросите у FixBot
    3. iPhone 11 Pro Max Taptic Engine Replacement: шаг 5, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 5, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 5, изображение 3 из 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Спросите у FixBot
    4. iPhone 11 Pro Max Taptic Engine Replacement: шаг 6, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 6, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 6, изображение 3 из 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Спросите у FixBot
    5. iPhone 11 Pro Max Taptic Engine Replacement, Heat the lower edge of the phone: шаг 7, изображение 1 из 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      Спросите у FixBot
    6. iPhone 11 Pro Max Taptic Engine Replacement: шаг 8, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement: шаг 8, изображение 2 из 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Спросите у FixBot
    7. iPhone 11 Pro Max Taptic Engine Replacement, Lift the display slightly: шаг 9, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Lift the display slightly: шаг 9, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Lift the display slightly: шаг 9, изображение 3 из 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Insert an opening pick into the gap.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Спросите у FixBot
    8. iPhone 11 Pro Max Taptic Engine Replacement, Separate the screen adhesive: шаг 10, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Separate the screen adhesive: шаг 10, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Separate the screen adhesive: шаг 10, изображение 3 из 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Спросите у FixBot
    9. iPhone 11 Pro Max Taptic Engine Replacement, Screen information: шаг 11, изображение 1 из 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Спросите у FixBot
    10. iPhone 11 Pro Max Taptic Engine Replacement: шаг 12, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 12, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 12, изображение 3 из 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Спросите у FixBot
    11. iPhone 11 Pro Max Taptic Engine Replacement: шаг 13, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 13, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement: шаг 13, изображение 3 из 3
      • The top edge of the display is secured with both glue and clips.
      • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
      • Insert your pick into the top-right corner of the phone.
      Спросите у FixBot
    12. iPhone 11 Pro Max Taptic Engine Replacement: шаг 14, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement: шаг 14, изображение 2 из 2
      • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
      • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      Спросите у FixBot
    13. iPhone 11 Pro Max Taptic Engine Replacement, Remove the suction cup: шаг 15, изображение 1 из 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Спросите у FixBot
    14. iPhone 11 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 16, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 16, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 16, изображение 3 из 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Спросите у FixBot
    1. iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the battery connector cover: шаг 17, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the battery connector cover: шаг 17, изображение 2 из 2
      Magnetic Project Mat
      $19.95
      • Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Спросите у FixBot
    2. iPhone 11 Pro Max Taptic Engine Replacement, Remove the battery connector cover: шаг 18, изображение 1 из 1
      • Remove the bracket.
      Спросите у FixBot
    3. iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 19, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 19, изображение 2 из 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Спросите у FixBot
    4. iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the logic board cover screws: шаг 20, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the logic board cover screws: шаг 20, изображение 2 из 2
      • Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
      Спросите у FixBot
    5. iPhone 11 Pro Max Taptic Engine Replacement, Remove the logic board cover bracket: шаг 21, изображение 1 из 1
      Спросите у FixBot
    6. iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the OLED display cable: шаг 22, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the OLED display cable: шаг 22, изображение 2 из 2
      • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    7. iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the front sensors + digitizer: шаг 23, изображение 1 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the front sensors + digitizer: шаг 23, изображение 2 из 3 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the front sensors + digitizer: шаг 23, изображение 3 из 3
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Спросите у FixBot
    8. iPhone 11 Pro Max Taptic Engine Replacement, Remove the display assembly: шаг 24, изображение 1 из 1
      Спросите у FixBot
    1. iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the lower battery connector cover: шаг 25, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the lower battery connector cover: шаг 25, изображение 2 из 2
      • Use a Y000 driver to remove the four 1.2 mm screws securing the lower battery connector cover.
      Спросите у FixBot
    2. iPhone 11 Pro Max Taptic Engine Replacement, Remove the cover: шаг 26, изображение 1 из 1
      • Remove the lower battery connector cover.
      Спросите у FixBot
    3. iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the lower battery connector: шаг 27, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the lower battery connector: шаг 27, изображение 2 из 2
      • Use a spudger to disconnect the lower battery flex cable by prying it straight up from its socket.
      Спросите у FixBot
    4. iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: шаг 28, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: шаг 28, изображение 2 из 2
      • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
      Спросите у FixBot
    5. iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the Taptic Engine: шаг 29, изображение 1 из 2 iPhone 11 Pro Max Taptic Engine Replacement, Unscrew the Taptic Engine: шаг 29, изображение 2 из 2
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the three screws securing the Taptic Engine:
      • One 2.0 mm-long Y000 screw
      • One 1.6 mm-long Y000 screw
      • One 4.0 mm-long standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Спросите у FixBot
    6. iPhone 11 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 1 из 1
      • Remove the Taptic Engine.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Max Answers community for help.
8 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
453 966 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 51 747 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 18
За последние 30 дней: 103
За всё время: 11,105
