iPhone 12 Pro Max Loudspeaker Replacement
Выберете то, что вам нужно
    1. iPhone 12 Pro Max Loudspeaker Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
      • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Спросите у FixBot
      Добавить комментарий
    1. iPhone 12 Pro Max Loudspeaker Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 12 Pro Max Loudspeaker Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Спросите у FixBot
    2. iPhone 12 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Спросите у FixBot
    3. iPhone 12 Pro Max Loudspeaker Replacement: шаг 5, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 5, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 5, изображение 3 из 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Спросите у FixBot
    4. iPhone 12 Pro Max Loudspeaker Replacement: шаг 6, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 6, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 6, изображение 3 из 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Спросите у FixBot
    5. iPhone 12 Pro Max Loudspeaker Replacement, Heat the bottom edge: шаг 7, изображение 1 из 1
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Спросите у FixBot
    6. iPhone 12 Pro Max Loudspeaker Replacement, Apply a suction cup: шаг 8, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Apply a suction cup: шаг 8, изображение 2 из 2
      • If you're using a single suction handle, apply it to the bottom edge of the screen.
      Спросите у FixBot
    7. iPhone 12 Pro Max Loudspeaker Replacement, Screen information: шаг 9, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Screen information: шаг 9, изображение 2 из 2
      • To avoid damaging your screen in the next step, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Спросите у FixBot
    8. iPhone 12 Pro Max Loudspeaker Replacement, Lift the screen slightly: шаг 10, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Lift the screen slightly: шаг 10, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Lift the screen slightly: шаг 10, изображение 3 из 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick at a steep angle into the gap.
      • Remember to insert the opening pick under the thick plastic bezel to avoid damaging your screen.
      Спросите у FixBot
    9. iPhone 12 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 11, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 11, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the bottom edge adhesive: шаг 11, изображение 3 из 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    10. iPhone 12 Pro Max Loudspeaker Replacement, Heat the right edge: шаг 12, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Heat the right edge: шаг 12, изображение 2 из 2
      • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Спросите у FixBot
    11. iPhone 12 Pro Max Loudspeaker Replacement: шаг 13, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 13, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement: шаг 13, изображение 3 из 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Спросите у FixBot
    12. iPhone 12 Pro Max Loudspeaker Replacement, Heat the top edge: шаг 14, изображение 1 из 1
      • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Спросите у FixBot
    13. iPhone 12 Pro Max Loudspeaker Replacement, Separate the top adhesive: шаг 15, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the top adhesive: шаг 15, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the top adhesive: шаг 15, изображение 3 из 3
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      Спросите у FixBot
    14. iPhone 12 Pro Max Loudspeaker Replacement, Heat the left edge: шаг 16, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Heat the left edge: шаг 16, изображение 2 из 2
      • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Спросите у FixBot
    15. iPhone 12 Pro Max Loudspeaker Replacement, Separate the left adhesive: шаг 17, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the left adhesive: шаг 17, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Separate the left adhesive: шаг 17, изображение 3 из 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Спросите у FixBot
    16. iPhone 12 Pro Max Loudspeaker Replacement, Open the iPhone: шаг 18, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Open the iPhone: шаг 18, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Open the iPhone: шаг 18, изображение 3 из 3
      • Rotate your iPhone so the right edge faces you.
      • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Спросите у FixBot
    17. iPhone 12 Pro Max Loudspeaker Replacement, Unscrew the battery and display connector cover: шаг 19, изображение 1 из 1
      Magnetic Project Mat
      $19.95
      • Remove four 1.1 mm-long Y000 screws securing the battery and display connector cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Спросите у FixBot
    18. iPhone 12 Pro Max Loudspeaker Replacement, Remove the battery and display connector cover: шаг 20, изображение 1 из 1
      • Remove the battery and display connector cover.
      Спросите у FixBot
    19. iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the battery: шаг 21, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the battery: шаг 21, изображение 2 из 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Спросите у FixBot
    20. iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the display cable: шаг 22, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the display cable: шаг 22, изображение 2 из 2
      • Use a spudger or a fingernail to disconnect the display cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    21. iPhone 12 Pro Max Loudspeaker Replacement, Unscrew the front sensor connector cover: шаг 23, изображение 1 из 1
      • Use a Y000 driver to remove the four 1.1 mm-long screws securing the front sensor connector cover.
      Спросите у FixBot
    22. iPhone 12 Pro Max Loudspeaker Replacement, Remove the front sensor connector cover: шаг 24, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Remove the front sensor connector cover: шаг 24, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Remove the front sensor connector cover: шаг 24, изображение 3 из 3
      • Swing the cover up from the left until the small clip on the right unhooks.
      • Remove the cover.
      • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
      Спросите у FixBot
    23. iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the front sensors: шаг 25, изображение 1 из 2 iPhone 12 Pro Max Loudspeaker Replacement, Disconnect the front sensors: шаг 25, изображение 2 из 2
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      Спросите у FixBot
    24. iPhone 12 Pro Max Loudspeaker Replacement, Remove the display assembly: шаг 26, изображение 1 из 1
      Спросите у FixBot
    1. iPhone 12 Pro Max Loudspeaker Replacement, Unscrew the loudspeaker: шаг 27, изображение 1 из 1
      • Use a Phillips driver to remove the four 1.4 mm screws securing the loudspeaker.
      Спросите у FixBot
    2. iPhone 12 Pro Max Loudspeaker Replacement, Remove the loudspeaker: шаг 28, изображение 1 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Remove the loudspeaker: шаг 28, изображение 2 из 3 iPhone 12 Pro Max Loudspeaker Replacement, Remove the loudspeaker: шаг 28, изображение 3 из 3
      • Slowly lift the loudspeaker out of its recess while gently peeling it off of its adhesive strip. Reapply this strip to the new loudspeaker.
      • Remove the loudspeaker.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Max Answers community for help.
17 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
224 467 Репутация
Автор 416 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 13
За последние 7 дней: 137
За последние 30 дней: 715
За всё время: 45,428
