iPhone 12 Pro Max Taptic Engine Replacement
Выберете то, что вам нужно
  1. iPhone 12 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 12 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 12 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Спросите у FixBot
  4. iPhone 12 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 12 Pro Max Taptic Engine Replacement: шаг 5, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 5, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  6. iPhone 12 Pro Max Taptic Engine Replacement: шаг 6, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 6, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 6, изображение 3 из 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  7. iPhone 12 Pro Max Taptic Engine Replacement, Heat the bottom edge: шаг 7, изображение 1 из 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    Спросите у FixBot
  8. iPhone 12 Pro Max Taptic Engine Replacement, Apply a suction cup: шаг 8, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Apply a suction cup: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
    Спросите у FixBot
  9. iPhone 12 Pro Max Taptic Engine Replacement, Lift the screen slightly: шаг 9, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Lift the screen slightly: шаг 9, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Lift the screen slightly: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick at a steep angle into the gap.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  10. iPhone 12 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 10, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 10, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 10, изображение 3 из 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  11. iPhone 12 Pro Max Taptic Engine Replacement, Heat the right edge: шаг 11, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Heat the right edge: шаг 11, изображение 2 из 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    Спросите у FixBot
  12. iPhone 12 Pro Max Taptic Engine Replacement: шаг 12, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 12, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement: шаг 12, изображение 3 из 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
    Спросите у FixBot
  13. iPhone 12 Pro Max Taptic Engine Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Use a hair dryer to heat the top edge of the iPhone until the screen is slightly too hot to touch.
    Спросите у FixBot
  14. iPhone 12 Pro Max Taptic Engine Replacement, Separate the top adhesive: шаг 14, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the top adhesive: шаг 14, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the top adhesive: шаг 14, изображение 3 из 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
    Спросите у FixBot
  15. iPhone 12 Pro Max Taptic Engine Replacement, Heat the left edge: шаг 15, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Heat the left edge: шаг 15, изображение 2 из 2
    • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
    Спросите у FixBot
  16. iPhone 12 Pro Max Taptic Engine Replacement, Separate the left adhesive: шаг 16, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the left adhesive: шаг 16, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Separate the left adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Спросите у FixBot
  17. iPhone 12 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 17, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 17, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Open the iPhone: шаг 17, изображение 3 из 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Спросите у FixBot
  18. iPhone 12 Pro Max Taptic Engine Replacement, Unscrew the battery and display connector cover: шаг 18, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove four 1.1 mm-long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Спросите у FixBot
  19. iPhone 12 Pro Max Taptic Engine Replacement, Remove the battery and display connector cover: шаг 19, изображение 1 из 1
    • Remove the battery and display connector cover.
    Спросите у FixBot
  20. iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Спросите у FixBot
  21. iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the display cable: шаг 21, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the display cable: шаг 21, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  22. iPhone 12 Pro Max Taptic Engine Replacement, Unscrew the front sensor connector cover: шаг 22, изображение 1 из 1
    • Use a Y000 driver to remove the four 1.1 mm-long screws securing the front sensor connector cover.
    Спросите у FixBot
  23. iPhone 12 Pro Max Taptic Engine Replacement, Remove the front sensor connector cover: шаг 23, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the front sensor connector cover: шаг 23, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the front sensor connector cover: шаг 23, изображение 3 из 3
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
    Спросите у FixBot
  24. iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
    Спросите у FixBot
  25. iPhone 12 Pro Max Taptic Engine Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
    Спросите у FixBot
  26. iPhone 12 Pro Max Taptic Engine Replacement, Unscrew the loudspeaker: шаг 26, изображение 1 из 1
    • Use a Phillips driver to remove the four 1.4 mm screws securing the loudspeaker.
    Спросите у FixBot
  27. iPhone 12 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 27, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 27, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 27, изображение 3 из 3
    • Slowly lift the loudspeaker out of its recess while gently peeling it off of its adhesive strip. Reapply this strip to the new loudspeaker.
    • Remove the loudspeaker.
    Спросите у FixBot
  28. iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine plastic cover: шаг 28, изображение 1 из 1
    • Use a Phillips driver to remove the 1.4 mm screw securing the Taptic Engine plastic cover.
    Спросите у FixBot
  29. iPhone 12 Pro Max Taptic Engine Replacement: шаг 29, изображение 1 из 1
    • Remove the plastic cover
    Спросите у FixBot
  30. iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 1 из 2 iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 2 из 2
    • Use the point of a spudger to pry the Taptic Engine connector straight up and out of its socket.
    Спросите у FixBot
  31. iPhone 12 Pro Max Taptic Engine Replacement: шаг 31, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the three screws securing the Taptic Engine:
    • Two 2.8 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 1.6 mm Phillips screw
    Спросите у FixBot
  32. iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 32, изображение 1 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 32, изображение 2 из 3 iPhone 12 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 32, изображение 3 из 3
    • Remove the Taptic Engine.
    • If you are replacing the Taptic Engine, remove the adhesive strip and transfer it to the new Taptic Engine before beginning reassembly.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Max Answers community for help.
8 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
223 550 Репутация
Автор 416 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 30
За последние 30 дней: 197
За всё время: 11,931
