iPhone 15 Pro Front Camera Assembly Replacement
Выберете то, что вам нужно
    1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 2 из 2
      • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Спросите у FixBot
      Добавить комментарий
    2. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
      • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: шаг 4, изображение 2 из 2
      • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Screen information: шаг 7, изображение 1 из 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Спросите у FixBot
    4. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    5. iPhone 15 Pro Front Camera Assembly Replacement, Heat the right edge: шаг 9, изображение 1 из 1
      • Heat the right edge of the screen until it's hot to the touch.
      Спросите у FixBot
    6. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: шаг 10, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: шаг 10, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: шаг 10, изображение 3 из 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Спросите у FixBot
    7. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: шаг 11, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: шаг 11, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: шаг 11, изображение 3 из 3
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      Спросите у FixBot
    8. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: шаг 12, изображение 3 из 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Спросите у FixBot
    9. iPhone 15 Pro Front Camera Assembly Replacement, Heat the top edge: шаг 13, изображение 1 из 1
      • Heat the top edge of the screen until it's hot to the touch.
      Спросите у FixBot
    10. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Спросите у FixBot
    11. iPhone 15 Pro Front Camera Assembly Replacement, Heat the left edge: шаг 15, изображение 1 из 1
      • Heat the left edge of the screen until it's hot to the touch.
      Спросите у FixBot
    12. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 16, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 16, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: шаг 16, изображение 3 из 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: шаг 17, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: шаг 17, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: шаг 17, изображение 3 из 3
      • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
      • Swing up the right edge of the screen like the front cover of a book.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      • Prop up the screen so you can access its cables without straining them.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: шаг 18, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: шаг 18, изображение 2 из 2
      • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
      • Four 1.6 mm‑long screws
      • Two 1.3 mm‑long screws
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: шаг 19, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: шаг 19, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: шаг 19, изображение 3 из 3
      • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
      • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
      Спросите у FixBot
    4. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: шаг 20, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: шаг 20, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: шаг 20, изображение 3 из 3
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Спросите у FixBot
    5. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: шаг 21, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: шаг 21, изображение 2 из 2
      • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
      Спросите у FixBot
    6. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: шаг 22, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: шаг 22, изображение 2 из 2
      • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
      • Lift the cable to disconnect it.
      Спросите у FixBot
    7. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: шаг 23, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: шаг 23, изображение 2 из 2
      • Remove the screen.
      • During reassembly, follow this guide to apply new adhesive and install your screen.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: шаг 24, изображение 3 из 3
      • Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
      • The third connector is hidden beneath the top one—lift the top cable slightly to reveal the third connector.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: шаг 25, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: шаг 25, изображение 2 из 2
      • Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
      • One 3.8 mm‑long screw
      • One 3.2 mm‑long screw
      • One 2.8 mm‑long screw
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: шаг 26, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: шаг 26, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: шаг 26, изображение 3 из 3
      • Be careful not to touch or smudge the camera lenses during this step.
      • Insert the point of a spudger between the top right corner of the rear cameras and frame.
      • Pry up until you can grab the rear cameras with your fingers.
      • Remove the rear cameras.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: шаг 27, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: шаг 27, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      Standoff Screwdriver for iPhones
      $5.49
      • Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
      • Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
      • If you don't have a standoff screwdriver, you can use a thin flathead one instead. Apply constant, downward pressure to avoid damaging the shallow notches in the screw head.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: шаг 28, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: шаг 28, изображение 2 из 2
      • Remove the earpiece speaker.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: шаг 29, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: шаг 29, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: шаг 29, изображение 3 из 3
      • The microphone cable covers the front sensors press connector.
      • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
      • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: шаг 30, изображение 3 из 3
      • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Remove the front camera assembly: шаг 31, изображение 1 из 1
      • Remove the front camera assembly.
      • Be careful not to touch or smudge the camera or sensor lenses.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Disassembly complete: шаг 32, изображение 1 из 1
      • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: шаг 33, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Install the front camera assembly: шаг 33, изображение 2 из 2
      • Be careful not to touch or smudge the front camera or sensor lenses.
      • If the replacement cameras include a plastic liner to protect the lenses, keep it in place until just before you reinstall the screen.
      • Use tweezers to align the front camera assembly with its recess in the frame and set it into place.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: шаг 34, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: шаг 34, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the front camera assembly: шаг 34, изображение 3 из 3
      • Use your finger or the flat end of a spudger to connect the front camera assembly's press connectors to their sockets on the top edge of the logic board.
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: шаг 35, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Connect the microphone: шаг 35, изображение 2 из 2
      • Use your finger to connect the microphone press connector to its socket on the top left corner of the logic board.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: шаг 36, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: шаг 36, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker: шаг 36, изображение 3 из 3
      • Align the gasket on the top right corner of the earpiece speaker with its recess in the frame.
      • Press the gasket into its recess, then lower the earpiece speaker into place.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: шаг 37, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Install the earpiece speaker screws: шаг 37, изображение 2 из 2
      • Use a Phillips #000 screwdriver to install the 2 mm‑long screw securing the top of the earpiece speaker.
      • Use a standoff screwdriver to install the remaining screw securing the bottom left corner of the earpiece speaker.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: шаг 38, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: шаг 38, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly: шаг 38, изображение 3 из 3
      • Be careful not to touch or smudge the camera lenses.
      • Align the rear camera assembly with its recess in the frame and set it into place.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: шаг 39, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Install the rear camera assembly screws: шаг 39, изображение 2 из 2
      • Use a Phillips #000 screwdriver to install the three screws securing the rear cameras:
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: шаг 40, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: шаг 40, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the rear cameras: шаг 40, изображение 3 из 3
      • Use the flat end of a spudger to connect the three rear camera press connectors—starting with the black one—to their respective sockets on the logic board.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: шаг 41, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: шаг 41, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen adhesive: шаг 41, изображение 3 из 3
      • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement: шаг 42, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 42, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 42, изображение 3 из 3
      • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
      • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
      • Wipe along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement, Orient the adhesive: шаг 43, изображение 1 из 1
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
      Спросите у FixBot
    4. iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: шаг 44, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: шаг 44, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Apply the adhesive: шаг 44, изображение 3 из 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, set it down along the bottom edge.
      Спросите у FixBot
    5. iPhone 15 Pro Front Camera Assembly Replacement: шаг 45, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 45, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 45, изображение 3 из 3
      • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
      Спросите у FixBot
    6. iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: шаг 46, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: шаг 46, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Press the adhesive into place: шаг 46, изображение 3 из 3
      • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Спросите у FixBot
    7. iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: шаг 47, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the top liner: шаг 47, изображение 2 из 2
      • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
      Спросите у FixBot
    8. iPhone 15 Pro Front Camera Assembly Replacement, Adhesive information: шаг 48, изображение 1 из 1
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
      Спросите у FixBot
    9. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: шаг 49, изображение 1 из 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Спросите у FixBot
    10. iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: шаг 50, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: шаг 50, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Connect the screen and ambient light sensor: шаг 50, изображение 3 из 3
      • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
      Спросите у FixBot
    11. iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: шаг 51, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Connect the battery: шаг 51, изображение 2 из 2
      • Use your finger or the flat end of a spudger to connect the battery press connector.
      Спросите у FixBot
    12. iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: шаг 52, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: шаг 52, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Install the logic board cover: шаг 52, изображение 3 из 3
      Спросите у FixBot
    13. iPhone 15 Pro Front Camera Assembly Replacement, Fasten the logic board cover: шаг 53, изображение 1 из 1
      • Use a Y000 screwdriver to install the six screws securing the logic board cover:
      Спросите у FixBot
    14. iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: шаг 54, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: шаг 54, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: шаг 54, изображение 3 из 3
      • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
      • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
      Спросите у FixBot
    15. iPhone 15 Pro Front Camera Assembly Replacement: шаг 55, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement: шаг 55, изображение 2 из 2
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
      Спросите у FixBot
    16. iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: шаг 56, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: шаг 56, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Place the screen: шаг 56, изображение 3 из 3
      • Align the screen over the frame, then lower it into place.
      Спросите у FixBot
    17. iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: шаг 57, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Press the screen: шаг 57, изображение 2 из 2
      • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
      Спросите у FixBot
    18. iPhone 15 Pro Front Camera Assembly Replacement, Install the pentalobe screws: шаг 58, изображение 1 из 1
      • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
      Спросите у FixBot
    19. iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: шаг 59, изображение 1 из 2 iPhone 15 Pro Front Camera Assembly Replacement, Heat the screen: шаг 59, изображение 2 из 2
      • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
      • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
      Спросите у FixBot
    1. iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: шаг 60, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: шаг 60, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement, Press the back glass: шаг 60, изображение 3 из 3
      • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the iPhone's original box, take the lid and place it on a flat surface.
      • If you don't have the original box, skip this step for an alternate method.
      • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
      • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes, ideally overnight.
      Спросите у FixBot
    2. iPhone 15 Pro Front Camera Assembly Replacement: шаг 61, изображение 1 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 61, изображение 2 из 3 iPhone 15 Pro Front Camera Assembly Replacement: шаг 61, изображение 3 из 3
      • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Спросите у FixBot
    3. iPhone 15 Pro Front Camera Assembly Replacement: шаг 62, изображение 1 из 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Спросите у FixBot
Заключение
Congratulations on replacing the front camera assembly!
After your repair, depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
2 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
198 095 Репутация
Автор 1 243 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 48 766 руководств
1 Комментарий к руководству
with ios 18, can you use the repair assistant tool to fix faceid? if not is there some sort of device i can use to pair the logic board with the faceid? if not, is my best bet for the front camera and faceid to work again just sending it in to apple for repairs?
Jesse Beckmann - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 13
За последние 7 дней: 132
За последние 30 дней: 495
За всё время: 11,340
