iPhone 16 Pro Max Battery Removal
Введение
Перейти к шагу 1Removal steps for the battery in the iPhone 16 Pro Max.
Выберете то, что вам нужно
Инструменты
Показать больше…
Use the tip of an opening pick to separate a black pull tab from the bottom of the battery.
Use tweezers to help peel the tab away from the battery.
Use tweezers or your fingers to grab the pull tab.
Slowly pull the adhesive out from under the battery at as low of an angle as possible.
If you removed all three stretch release adhesive strips, congratulations! Remove the battery and skip down three steps for reassembly instructions.
Lift the bottom edge of the frame to tilt the iPhone.
Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
Insert the flat edge of an opening pick between the left edge of the battery and the frame.
Pry the battery upwards slowly with steady force. Give the adhesive time to release.
Once the adhesive loosens, grab and remove the battery.
