iPhone 7 Lightning Connector Assembly Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 7 Lightning Connector Assembly Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  4. iPhone 7 Lightning Connector Assembly Replacement: шаг 4, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 4, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  5. iPhone 7 Lightning Connector Assembly Replacement: шаг 5, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  6. iPhone 7 Lightning Connector Assembly Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  7. iPhone 7 Lightning Connector Assembly Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  8. iPhone 7 Lightning Connector Assembly Replacement: шаг 8, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 8, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  9. iPhone 7 Lightning Connector Assembly Replacement: шаг 9, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 9, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Спросите у FixBot
  10. iPhone 7 Lightning Connector Assembly Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  11. iPhone 7 Lightning Connector Assembly Replacement: шаг 11, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 11, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  12. iPhone 7 Lightning Connector Assembly Replacement: шаг 12, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  13. iPhone 7 Lightning Connector Assembly Replacement: шаг 13, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 13, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  14. iPhone 7 Lightning Connector Assembly Replacement: шаг 14, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  15. iPhone 7 Lightning Connector Assembly Replacement: шаг 15, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 15, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  16. iPhone 7 Lightning Connector Assembly Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
    Спросите у FixBot
  17. iPhone 7 Lightning Connector Assembly Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
    Спросите у FixBot
  18. iPhone 7 Lightning Connector Assembly Replacement: шаг 18, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 18, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Спросите у FixBot
  19. iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Спросите у FixBot
  20. iPhone 7 Lightning Connector Assembly Replacement: шаг 20, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 20, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Спросите у FixBot
  21. iPhone 7 Lightning Connector Assembly Replacement: шаг 21, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Спросите у FixBot
  22. iPhone 7 Lightning Connector Assembly Replacement: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 7 Lightning Connector Assembly Replacement, Barometric Vent: шаг 23, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    Спросите у FixBot
  24. iPhone 7 Lightning Connector Assembly Replacement: шаг 24, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 24, изображение 2 из 2
    • Remove the vent.
    Спросите у FixBot
  25. iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: шаг 25, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: шаг 25, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    Спросите у FixBot
  26. iPhone 7 Lightning Connector Assembly Replacement: шаг 26, изображение 1 из 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    Спросите у FixBot
  27. iPhone 7 Lightning Connector Assembly Replacement: шаг 27, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 27, изображение 2 из 2
    • Remove the Taptic Engine.
    Спросите у FixBot
  28. iPhone 7 Lightning Connector Assembly Replacement, Speaker Assembly: шаг 28, изображение 1 из 1
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
    Спросите у FixBot
  29. iPhone 7 Lightning Connector Assembly Replacement: шаг 29, изображение 1 из 1
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
    Спросите у FixBot
  30. iPhone 7 Lightning Connector Assembly Replacement: шаг 30, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 30, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 30, изображение 3 из 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Спросите у FixBot
  31. iPhone 7 Lightning Connector Assembly Replacement: шаг 31, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 31, изображение 2 из 2
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
    Спросите у FixBot
  32. iPhone 7 Lightning Connector Assembly Replacement: шаг 32, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 32, изображение 2 из 2
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
    Спросите у FixBot
  33. iPhone 7 Lightning Connector Assembly Replacement: шаг 33, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 33, изображение 2 из 2
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
    Спросите у FixBot
  34. iPhone 7 Lightning Connector Assembly Replacement: шаг 34, изображение 1 из 1
    • Remove the speaker.
    Спросите у FixBot
  35. iPhone 7 Lightning Connector Assembly Replacement, SIM Card: шаг 35, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: шаг 35, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: шаг 35, изображение 3 из 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Спросите у FixBot
  36. iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: шаг 36, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: шаг 36, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    Спросите у FixBot
  37. iPhone 7 Lightning Connector Assembly Replacement: шаг 37, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 37, изображение 2 из 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    Спросите у FixBot
  38. iPhone 7 Lightning Connector Assembly Replacement: шаг 38, изображение 1 из 1
    • Remove the bracket.
    Спросите у FixBot
  39. iPhone 7 Lightning Connector Assembly Replacement: шаг 39, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 39, изображение 2 из 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    Спросите у FixBot
  40. iPhone 7 Lightning Connector Assembly Replacement: шаг 40, изображение 1 из 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    Спросите у FixBot
  41. iPhone 7 Lightning Connector Assembly Replacement: шаг 41, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 41, изображение 2 из 2
    • Remove the upper cable bracket.
    Спросите у FixBot
  42. iPhone 7 Lightning Connector Assembly Replacement: шаг 42, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 42, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
    Спросите у FixBot
  43. iPhone 7 Lightning Connector Assembly Replacement: шаг 43, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 43, изображение 2 из 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    Спросите у FixBot
  44. iPhone 7 Lightning Connector Assembly Replacement: шаг 44, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 44, изображение 2 из 2
    • Remove the top left antenna.
    Спросите у FixBot
  45. iPhone 7 Lightning Connector Assembly Replacement: шаг 45, изображение 1 из 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    Спросите у FixBot
  46. iPhone 7 Lightning Connector Assembly Replacement: шаг 46, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 46, изображение 2 из 2
    Спросите у FixBot
  47. iPhone 7 Lightning Connector Assembly Replacement: шаг 47, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Спросите у FixBot
  48. iPhone 7 Lightning Connector Assembly Replacement: шаг 48, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 48, изображение 2 из 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    Спросите у FixBot
  49. iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: шаг 49, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: шаг 49, изображение 2 из 2
    • Use the point of a spudger to disconnect the lower cable connector.
    Спросите у FixBot
  50. iPhone 7 Lightning Connector Assembly Replacement: шаг 50, изображение 1 из 1
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    Спросите у FixBot
  51. iPhone 7 Lightning Connector Assembly Replacement: шаг 51, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 51, изображение 2 из 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    Спросите у FixBot
  52. iPhone 7 Lightning Connector Assembly Replacement: шаг 52, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 52, изображение 2 из 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    Спросите у FixBot
  53. iPhone 7 Lightning Connector Assembly Replacement: шаг 53, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 53, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 53, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Спросите у FixBot
  54. iPhone 7 Lightning Connector Assembly Replacement: шаг 54, изображение 1 из 1
    • Remove the 2.9 mm Phillips screw from the lightning connector.
    Спросите у FixBot
  55. iPhone 7 Lightning Connector Assembly Replacement: шаг 55, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 55, изображение 2 из 2
    • Remove the spring contact from the lightning connector.
    Спросите у FixBot
  56. iPhone 7 Lightning Connector Assembly Replacement: шаг 56, изображение 1 из 1
    • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
    Спросите у FixBot
  57. iPhone 7 Lightning Connector Assembly Replacement: шаг 57, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 57, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 57, изображение 3 из 3
    • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
    Спросите у FixBot
  58. iPhone 7 Lightning Connector Assembly Replacement: шаг 58, изображение 1 из 1
    • Remove the two 1.3 mm Phillips screws from the rear case.
    Спросите у FixBot
  59. iPhone 7 Lightning Connector Assembly Replacement: шаг 59, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 59, изображение 2 из 2
    • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
    Спросите у FixBot
  60. iPhone 7 Lightning Connector Assembly Replacement: шаг 60, изображение 1 из 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
    • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
    • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
    Спросите у FixBot
  61. iPhone 7 Lightning Connector Assembly Replacement: шаг 61, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 61, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 61, изображение 3 из 3
    • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
    Спросите у FixBot
  62. iPhone 7 Lightning Connector Assembly Replacement: шаг 62, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 62, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 62, изображение 3 из 3
    • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
    Спросите у FixBot
  63. iPhone 7 Lightning Connector Assembly Replacement: шаг 63, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 63, изображение 2 из 2
    • Continue to slide the pick underneath the lightning connecter assembly.
    • Stop sliding the pick once it passes the battery.
    Спросите у FixBot
  64. iPhone 7 Lightning Connector Assembly Replacement: шаг 64, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 64, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 64, изображение 3 из 3
    • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
    • Stop sliding the pick when it reaches the lightning connector.
    Спросите у FixBot
  65. iPhone 7 Lightning Connector Assembly Replacement: шаг 65, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 65, изображение 2 из 2
    • Gently pull the lightning connector out of its hole on the rear case.
    Спросите у FixBot
  66. iPhone 7 Lightning Connector Assembly Replacement: шаг 66, изображение 1 из 2 iPhone 7 Lightning Connector Assembly Replacement: шаг 66, изображение 2 из 2
    • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
    • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
    Спросите у FixBot
  67. iPhone 7 Lightning Connector Assembly Replacement: шаг 67, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 67, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 67, изображение 3 из 3
    • Remove the lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
    Спросите у FixBot
  68. iPhone 7 Lightning Connector Assembly Replacement: шаг 68, изображение 1 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 68, изображение 2 из 3 iPhone 7 Lightning Connector Assembly Replacement: шаг 68, изображение 3 из 3
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 7 Answers community for troubleshooting help.
284 человек успешно провели ремонт по этому руководству.
Scott Havard
Участник с: 06/27/16
51 299 Репутация
Автор 31 руководств
54 Комментарии к руководству
The old ones were so easy! Why did Apple have to put the thing under the board!!!???
Christopher Crawford - Ответить Поделиться
Prob to discourage people from replacing it themselves instead of sending to apple
Elwen Omara - Ответить Поделиться
I dunno. It was a pain, but surprisingly I got mine fixed. When I took it to the apple store they flat out told me that they wouldn’t fix it at all. I couldn’t even send it in to them. Something about no communication with the logic board and they refused to touch it. Thankfully the guides are detailed enough for goofs like me to be successful.
Ray Bieze - Ответить Поделиться
Ho un problema dopo aver installato il nuovo connettore. Quando l’iphone e scarico, inserendo il cavo, appare sul display il simbolo batteria. Una volta acceso il cavo non viene più segnalato e la ricarica non continua. Cosa può essere?
Fabio - Ответить Поделиться
Salve ho lo stesso problema,qual è il problema?
lorenzo Serra - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 23
За последние 7 дней: 151
За последние 30 дней: 1,304
За всё время: 468,141
