iPhone 8 Rear Camera Replacement
Выберете то, что вам нужно
  1. iPhone 8 Rear Camera Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 8 Rear Camera Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 8 Rear Camera Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 8 Rear Camera Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 8 Rear Camera Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 8 Rear Camera Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 8 Rear Camera Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  4. iPhone 8 Rear Camera Replacement: шаг 4, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 4, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  5. iPhone 8 Rear Camera Replacement: шаг 5, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  6. iPhone 8 Rear Camera Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  7. iPhone 8 Rear Camera Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 8 Rear Camera Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  8. iPhone 8 Rear Camera Replacement: шаг 8, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 8, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  9. iPhone 8 Rear Camera Replacement: шаг 9, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 9, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Спросите у FixBot
  10. iPhone 8 Rear Camera Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  11. iPhone 8 Rear Camera Replacement: шаг 11, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 11, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  12. iPhone 8 Rear Camera Replacement: шаг 12, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  13. iPhone 8 Rear Camera Replacement: шаг 13, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 13, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  14. iPhone 8 Rear Camera Replacement: шаг 14, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  15. iPhone 8 Rear Camera Replacement: шаг 15, изображение 1 из 3 iPhone 8 Rear Camera Replacement: шаг 15, изображение 2 из 3 iPhone 8 Rear Camera Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  16. iPhone 8 Rear Camera Replacement, Disconnect the battery: шаг 16, изображение 1 из 2 iPhone 8 Rear Camera Replacement, Disconnect the battery: шаг 16, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
    Спросите у FixBot
  17. iPhone 8 Rear Camera Replacement: шаг 17, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 17, изображение 2 из 2
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Спросите у FixBot
  18. iPhone 8 Rear Camera Replacement, Disconnect the display and digitizer: шаг 18, изображение 1 из 2 iPhone 8 Rear Camera Replacement, Disconnect the display and digitizer: шаг 18, изображение 2 из 2
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    Спросите у FixBot
  19. iPhone 8 Rear Camera Replacement: шаг 19, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 19, изображение 2 из 2
    • Use the point of a spudger to disconnect the second lower display cable.
    Спросите у FixBot
  20. iPhone 8 Rear Camera Replacement: шаг 20, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 20, изображение 2 из 2
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    Спросите у FixBot
  21. iPhone 8 Rear Camera Replacement: шаг 21, изображение 1 из 2 iPhone 8 Rear Camera Replacement: шаг 21, изображение 2 из 2
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
    Спросите у FixBot
  22. iPhone 8 Rear Camera Replacement, Remove the display assembly: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 8 Rear Camera Replacement, Disconnect the rear camera: шаг 23, изображение 1 из 2 iPhone 8 Rear Camera Replacement, Disconnect the rear camera: шаг 23, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
    Спросите у FixBot
  24. iPhone 8 Rear Camera Replacement, Remove the rear camera bracket: шаг 24, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Спросите у FixBot
  25. iPhone 8 Rear Camera Replacement: шаг 25, изображение 1 из 1
    • Remove the rear-facing camera bracket.
    Спросите у FixBot
  26. iPhone 8 Rear Camera Replacement, Remove the rear camera: шаг 26, изображение 1 из 2 iPhone 8 Rear Camera Replacement, Remove the rear camera: шаг 26, изображение 2 из 2
    • Remove the rear camera by lifting it straight up out of its recess.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
40 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 174 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 32 276 руководств
9 Комментарии к руководству
Does the rear camera assembly include the camera glass?
Jacob Mattrella - Ответить Поделиться
Hi Jacob,
The rear camera assembly is only the module itself. It does not include the glass mounted on the rear case.
Arthur Shi - Ответить Поделиться
Is the iPhone still waterproof after the repair?
Thorn Deil - Ответить Поделиться
Many people say that it’s not…
Even if you replace the adhesives securing the display.
The same goes with the rubber protecting the hole where the cable enter, or the rubbers or what ever that It’s protecting the buttons to keep the water away …
With time this protective things gets old and fail to do it’s job, it’s normal.
But I Guess that it’s better than not replacing the adhesives at all…
David Novo - Ответить Поделиться
Does this camera module also works for the iPhone 7? Or should I only stick to the iPhone 7 one? That could be a nice upgrade if I already need to change it
Carlos gonzalez - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 66
За последние 30 дней: 303
За всё время: 108,738
