Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Вопрос закрыт
Building Extra LiPo Mac Battery
I want to buy some Lithium Polymer batteries off a website and solder a mag socket power switch (the Standard Mac Power Plug) to it. I'm assuming I will need a 5 Cell battery because the voltage would be 18.5V
Is this true? Can I just make a backup battery for, say, on an airplane or in a car?
Thanks!
Это хороший вопрос?
Оценка -1
1 Комментарий
Thanks for both replies!
Well, I've been talking to my dad about it and so far it seems I will need about 5 Amps at 18.5 volts which would be great for a 5000 mAh 5 Cell LiPo with a 10C rating. Not too much in terms of the actual battery, but it should be able to give about 1.6x the capacity of the laptop's battery.
It will cost over $100 to do, so I doubt I will do it, but if I do, I will post it!
из
Добавить комментарий
Ответов (2)
Выбранное решение
To me something like this dc to ac adapter for autos and airplanes would make more sense, but I'm sure you could make such a battery. To me the problem would be housing it and recharging. Good luck whichever way you go. Ralph
http://eshop.macsales.com/item/Kensingto...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
The unknown factor would be any circuitry in a normal battery. Ralph
из
After conducting some research on how the MacBook Pro AC power adapter works, I have concluded that building a custom LiPo battery pack would not be significantly cheaper than buying from a 3rd party (specifically a HyperMac battery). The reason for this is because the AC power adapter outputs 16.5V for normal operations and switches to 18.5V for intensive tasks. Building a custom external battery that could do this would not be cost-effective. Also, I believe there may be some differences in current draw when the MacBook Pro is charging vs. 100% charged.
из
Here we are two years later...I have not done it, but E Rogers did, for under $60.
http://www.theverge.com/2012/4/2/2905463...
Оценка 0
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,950
